Hello
I have some fault codes with my Touran, some not so serious, but two of them bothers me. Occasionally the steering wheel starts to shudder or vibrate and it comes a strange sound from underneath the engine bay, maybe power steering pump? I have fault codes both for steering control module and ignition lock. Is it possible these are related, or do I have both a faulty ingnition lock and a control module/steering rack problem?
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 752 0101
Coding: 0002022
Shop #: WSC 01324 785 00200
VCID: 0103EEF158ECDE29605-8054
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
5 Faults Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A51695D851AFD7111F-807F
2 Faults Found:
16344 - Control Module - RAM Error
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 6
Fault Frequency: 1
Reset counter: 100
Time Indication: 0
Freeze Frame:
Voltage: 7.88 V
PD
Temperature: -3.0°C
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0xADB4
Count: 4
16355 - Control Module - Watchdog Timer
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 100
Time Indication: 0
Freeze Frame:
Voltage: 7.88 V
PD
Temperature: -3.0°C
Count: 0
Count: 25
Count: 44
Count: 0
