Thread: Help polo 2001 1.4 auto check engine/epc light on
  1. Help polo 2001 1.4 auto check engine/epc light on
    • Sunday,28,April,2019,13:27:22:07086
      VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
      VCDS Version: 18.9.1.0 (x64)
      Data version: 20190114 DS296.0
      www.Ross-Tech.com
      VIN: WVWZZZ6NZ1Y267941 License Plate:
      IF IT'S THE LAMBDA SENSOR....THEN WHICH ONE IS IT...AS THERE IS ONE IN ENGINE BAY UNDER MANIFOLD AND ONE UNDER ACTUAL CAR ?
      Chassis Type: 6N (6N - VW Polo (1995 > 2002))
      Scan: 01 02 03 08 15 17 19 25 41 45 46 55 56
      VIN: WVWZZZ6NZ1Y267941 Mileage: 134120km-83338miles
      Address 01: Engine Labels: 036-906-034-APE.lbl
      Part No: 036 906 034 BE
      Component: MARELLI 4LV 3768
      Coding: 00033
      Shop #: WSC 00000
      VCID: 56A99516B21CF3FAD7-4B4A
      6 Faults Found:
      16706 - Engine Speed Sensor (G28)
      P0322 - 35-10 - No Signal - Intermittent
      16497 - Intake Air Temp. Sensor (G42)
      P0113 - 35-10 - Signal too High - Intermittent
      17961 - Barometric / Manifold Pressure Signals
      P1553 - 35-10 - Implausible Correlation - Intermittent
      17513 - Oxygen (Lambda) Sensor Heating; B1 S2; Heating Circuit
      P1105 - 35-00 - Short to Plus
      16727 - Camshaft Position Sensor (G40)
      P0343 - 35-00 - Signal too High
      17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1
      P1196 - 35-00 - Electrical Malfunction
      Readiness: 1010 0101
      Address 02: Auto Trans Labels: 001-927-731.lbl
      Part No: 001 927 731 K
      Component: AG4 Getriebe 001 2978
      VCID: 1933DE2A83821C823A-5170
      3 Faults Found:
      00529 - Engine Speed Signal Missing
      03-10 - No Signal - Intermittent
      01166 - Engine Torque Signal
      16-10 - Signal Outside Specifications - Intermittent
      Address 03: ABS Brakes Labels: 6X0-907-379.lbl
      Part No: 6X0 907 379 B
      Component: ABS 30 IE CAN V004
      Coding: 05603
      Shop #: WSC 00788
      VCID: 438F5C42518E765280-4B18
      No fault code found.
      Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
      Part No: 6Q0 909 601
      Component: 15 AIRBAG VW5 0006
      Coding: 12597
      Shop #: WSC 00788
      VCID: 70E5C38E30B8BDCA2D-5154
      Address 17: Instruments Labels: 6N0-920-xxx-17.lbl
      Part No: 6N0 920 904 D
      Component: KOMBIINSTRUMENT BOO V12
      Coding: 00441
      Shop #: WSC 00258
      VCID: 3065038EF038FDCA6D-5154
      Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
      Part No: 6N0 909 901
      Component: Gateway K<->CAN
      Coding: 00023
      Shop #: WSC 00788
      Address 25: Immobilizer Labels: 6X0-953-257.lbl
      Part No: 6X0 953 257
      Component: IMMO 0008
      Coding: 00001
      Shop #: WSC 00050
      VCID: 7DFBEABA77EAC0A2B6-4B00
      WVWZZZ6NZ1Y267941 VWZ1Z0A1337644
      Address 56: Radio Labels: 1J0-035-15x-56.lbl
      Part No: 6X0 035 152 B
      Component: Radio BNO 0005
      Coding: 00001
      Shop #: WSC 00788
      VCID: 3065038EF038FDCA6D-4AE8
      End-------------------------(Elapsed Time: 02:44)--------------------------
    • Today, 07:50 AM
      vw754
      Verified VCDS UserJoin DateNov 2016LocationUKPosts68Post Thanks / Like
      cleared codes....drove it,rechecked.......
      Sunday,28,April,2019,13:49:12:07086
      VCDS Version: Release 18.9.1 (x64) Running on Windows 8.1 x64
      www.Ross-Tech.com
      Control Module Part Number: 036 906 034 BE
      Component and/or Version: MARELLI 4LV 3768
      Software Coding: 00033
      Work Shop Code: WSC 00000
      6 Faults Found:
      P1553 - 35-00 - Implausible Correlation
      17524 - Oxygen (Lambda) Sensor Heating; B1 S1
      P1116 - 35-00 - Open Circuit
  2. Re: Help polo 2001 1.4 auto check engine/epc light on
    1836 Post(s)
    That car has an AUE engine, VCDS is incorrectly labelling it an APE but it’s not important. I would like to study the wiring diagram against those codes so give me a prod in the morning to remind me. The lambda sensor code are pointing to both sensors, B1 means bank 1 and it only has one bank but S1 is sensor one pre cat and S2 is sensor 2 post cat. I think you have a wiring fault in the plug/wiring from the gearbox bracket plug to body harness area.
  3. Re: Help polo 2001 1.4 auto check engine/epc light on
    Jun 2016
    Glasgow
    Clear them all. What comes back? Post here.
  1. Please Help 2001 X Polo 1.4 Engine Management Light
    By culley in forum Polo - Derby - Lupo - Fox
    Last Post: 20-02-2014, 08:26 PM
  2. 2001-2005 A4 - Engine Check Light - Brake Boost - System too lean - System too Rich
    By A4nutter in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 14-10-2009, 09:45 PM
  3. 2001 Polo Auto 1.4 16V 6N2 EPC LOW REVS
    By eromad in forum Polo - Derby - Lupo - Fox
    Last Post: 15-06-2009, 02:30 PM
  4. VW Polo 1.4 auto 2000 Engine management light probs
    By M'lady in forum Polo - Derby - Lupo - Fox
    Last Post: 06-12-2007, 03:16 PM
  5. 2001 Polo 1.4 SE Auto Diagnostic Port?
    By sbhammo in forum Polo - Derby - Lupo - Fox
    Last Post: 19-10-2007, 09:20 PM
