Thread: Help! What lowering springs?!
  1. Help! What lowering springs?!
    Apr 2019
    I’ve got a 2012 MK6 GOLF MATCH 2.0 TDI. GOT A SET OF 18” GTD ALLOYS BUT I WANT TO LOWER IT BEFORE FITTING THEM AS IT WILL LOOK STUPID WITH STOCK HEIGHT.
    I ONLY WANT A SLIGHT DROP, NOT TO LOW.
    IM GOING FOR A 25MM DROP BUT DO I GET 20/25MM OR 25/25MM?
  2. Re: Help! What lowering springs?!
    1837 Post(s)
    The amount of drop varies and can even be as much as 5mm different one side to the other even from new, so start by measuring what you have from the centre of the wheel to the lower turned in edge of the wheel arch at 12 o’clock. Eibach springs are amongst the best you can buy VW Golf Mk6 1.4TSI, 1.8TSI, 1.6TDI, 2.0TDI 10/08 on Eibach Pro-Kit 4050278008099 | eBay
  1. Question Lowering springs
    By Golf TD in forum Golf MK5 - 2004 - 2009
    Last Post: 26-10-2016, 06:53 PM
  2. Lowering springs... how low should I go?
    By hairyape1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-08-2012, 06:49 PM
  3. lowering springs
    By dave_g1007 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-03-2010, 07:14 PM
  4. Question lowering springs
    By gt tdi fella in forum Golf MK4 - 1999 - 2004
    Last Post: 27-04-2009, 07:04 PM
  5. lowering springs
    By hogiapesda in forum Golf MK4 - 1999 - 2004
    Last Post: 24-12-2007, 10:53 PM
