Thread: Any pictures of a Passat CC lowered 40mm? + Are standard shocks okay to use?
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Any pictures of a Passat CC lowered 40mm? + Are standard shocks okay to use?
    #11
    Sep 2016
    Nairn
    About to drop some money on eibachs, quick check please, will these fit my 2014 CC 2.0tdi with dcc shocks
    Eibach Pro Kit Lowering Springs VW Passat Mk6 CC 2.0 TSI, 2.0 TDI (06/08 >) | eBay
    Also do I need anything else while ordering new springs? Car is at 33k miles so nothing is too worn out yet
  2. Re: Any pictures of a Passat CC lowered 40mm? + Are standard shocks okay to use?
    #12
    1835 Post(s)
    Every nut and bolt you remove must be replaced with the correct OE spec parts and it may need new rear bump stops. You may find it does not drop it a full 40mm as your car properly has factory lowering springs and the Eibach stated drop is for standard ride height.
  3. Re: Any pictures of a Passat CC lowered 40mm? + Are standard shocks okay to use?
    #13
    Sep 2016
    Nairn
    So the eibach prob won’t be much difference? Sounds like hr springs will actually lower the car noticeably even if it isn’t 40mm it’s gonna be better than a gestimated 15mm for the eibachs as r lines are all ready lower
    Is there any websites with diagrams of the car parts so I can find out what nuts and bolts I need? I don’t see how I’m meant to carry out this work without having such information available before I start the work.
  4. Re: Any pictures of a Passat CC lowered 40mm? + Are standard shocks okay to use?
    #14
    1835 Post(s)
    Sign up to https://erwin.volkswagen.de and you can download and save as a pdf the files you want but work fast as that hours disappears very quickly. As for the part numbers, if you show the dealer of TPS the diagrams with your VIN they should be able to work out what you need. The H&R springs tend to be much like Eibach, if you wanted to go lower you could use Eibach sportsline red springs but the ride will be atrocious.
  5. Re: Any pictures of a Passat CC lowered 40mm? + Are standard shocks okay to use?
    #15
    Sep 2016
    Nairn
    That’s awesome thanks for the link.
    Eibach ordered, hopefully they drop a good 25mm plus as I’ve read the CC drops further than given sizes
  6. Re: Any pictures of a Passat CC lowered 40mm? + Are standard shocks okay to use?
    #16
    Oct 2020
    GB northern Ireland
    Hi all I have a Passat cc gt 2.0Tdi 2011 it has the electric suspension but it's not sounding to great it working tho when I change it to sport and then comfort I can feel it but I was looking to see if I can put Standard shock absorber as the electric shock absorbers are so expensive
  1. need pics of 3b estate 2000-2005 lowered 40mm
    By passatmick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-06-2010, 10:01 PM
  2. Koni FSD shocks on my passat
    By silverpassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-12-2009, 11:11 PM
  3. Lowered springs and shocks?
    By CherryB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-01-2009, 09:41 AM
  4. Cheapest place for standard shocks
    By Matt-h in forum Golf MK4 - 1999 - 2004
    Last Post: 30-07-2008, 10:07 PM
  5. Passat Shocks
    By rallye in forum Passat - Archive Topics
    Last Post: 20-02-2007, 11:36 PM
