Thread: mk5 golf gt tdi 170
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. Re: mk5 golf gt tdi 170
    #21
    1837 Post(s)
    001 and 002 I think, VCDS has labels that are usually correct....
  2. Re: mk5 golf gt tdi 170
    #22
    Jan 2019
    Crasher ive nit had chance yet to check the fuel pressure, but ive unplugged the fuel pump under the back seat and it started up without it plugged in and its running!!!!! It did cut out as soon as it got hot, just waiting for a new laptop so can use vcds as mine went boom lol rite also checked cam n crank eire for power and im getting power to them!!!
  3. Re: mk5 golf gt tdi 170
    #23
    1837 Post(s)
    It will run without the lift pump plugged in, it is just there to get fuel up to the tandem pump should there be an air lock and you often don't know the lift pump is faulty until the tank is low and it pulls air.
  4. Re: mk5 golf gt tdi 170
    #24
    Jan 2019
    Just ordered a new laptop 😡 bloody car is coasting me loads now, so what are we hoping to get from the fuel pressure then? If its low pressure what could we be looking towards? If i got power going to the crank n cam shaft sensor would it indicate that i have a etc or wiring fault as the air mass and coolant came up aswel?
  5. Re: mk5 golf gt tdi 170
    #25
    1837 Post(s)
    The BMN engine has no fuel pressure sensors to study the values of when using a diagnostic system.
  6. Re: mk5 golf gt tdi 170
    #26
    Jan 2019
    Hi crasher,
    how are you? sorry its took soo long ive been in hospitak etc and only just had time tonight to work on the car, so only just got your message tonight at 14/06/16 21:21
    anyways ive been trying to get the fuel pressure check up on the vcds and its only on fuel rails that it shows, so how would i get the fuel pressure? get a gauge and put it in between the fuel line etc? if so what kind of bar pressure am i looking for? sorry not very good at stuff like this.
    i got some logs from vcds i dunno if they will be very helpful or not but here they are
    Friday,14,June,2019,19:20:20:00007
    VCDS Version: 18.9.0.2 (x64)
    Data version: 20180927 DS296.0
    Ross-Tech: Home
    VIN: WVWZZZ1KZ7B029271 License Plate:
    Address 01: Engine
    Control Module Part Number: 03G 906 018 DF
    Component and/or Version: R4 2.0l PPD1.2 G 4345
    Software Coding: 0000072
    Work Shop Code: WSC 00191
    VCID: 6CD772B14F8BF02A19-8038
    Advanced Identification
    Serial number: VWZ7Z0F7033264
    Identification: SJ8-FST
    Revision: --H22---
    Date: 02.07.06
    Test stand number: 0415
    Manufacturer number: 0277
    Flash Status
    Programming Attempts: 6
    Successful Attempts: 6
    Programming Status: 00000000
    Required Conditions: 00000000
    Misc.
    Hardware number: 03G 906 018 DF
    Car Info
    Chassis Number: WVWZZZ1KZ7B029271
    VCDS Info:
    Labels: 03G-906-018-BMN.CLB
    Readiness: No script available
    Friday,14,June,2019,19:37:29:00007
    Ross-Tech: Home
    Address 01: Engine (03G 906 018 DF)
    19:37:27
    7.9 mg/str Injection Quantity
    4.4°KW Injection Duration (specified)
    32.0°C Fuel Temperature (G81)
    0.28 mg/str Injection Quantity Deviation Cyl. 1
    -0.56 mg/str Injection Quantity Deviation Cyl. 2
    1.82 mg/str Injection Quantity Deviation Cyl. 3
    -1.53 mg/str Injection Quantity Deviation Cyl. 4
    0.80 l/h Fuel Consumption
    Friday,07,June,2019,10:30:57:00007
    Ross-Tech: Home
    VIN: WVWZZZ1KZ7B029271 License Plate: SP56AHG
    Mileage: 246050km-152888mi Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: WVWZZZ1KZ7B029271 Mileage: 246050km-152888miles
    01-Engine -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 1010
    15-Airbags -- Status: OK 0000
    42-Door Elect, Driver -- Status: Sporadic communication error 1000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 1010
    52-Door Elect, Pass. -- Status: Sporadic communication error 1000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: Sporadic communication error 1000
    72-Door, Rear Right -- Status: Sporadic communication error 1000
    7D-Aux. Heat -- Status: Malfunction 1010
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 DF HW: 03G 906 018 DF
    Component: R4 2.0l PPD1.2 G 4345
    Revision: --H22--- Serial number: VWZ7Z0F7033264
    Coding: 0000072
    Shop #: WSC 00191 264 15243
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    Shop #: WSC 00878 210 92199
    VCID: 73E569CD12B52FD2D8-8026
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 FH
    Component: Climatic PQ35 120 0606
    Shop #: WSC 00000 000 00000
    VCID: 6FED65BD7E9D0B323C-803A
    3 Faults Found:
    00402 - Auxiliary Air Heater Element (Z35)
    00457 - Control Module for Network (J519)
    013 - Check DTC Memory
    00229 - Refrigerant Pressure
    002 - Lower Limit Exceeded
    Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
    Component: Bordnetz-SG H37 1002
    Revision: 00H37000 Serial number: 00000004241640
    Coding: E5890F2700041500001400001400000000087F075C
    Shop #: WSC 00046 000 278528
    VCID: 2B55B1AD8A05371250-807E
    Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 230606 020 0501
    Coding: 00038805
    Shop #: WSC 00046
    Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
    Component: RLS 191006 014 1201
    Coding: 00208933
    Shop #: WSC 00046
    10 Faults Found:
    02071 - Local Databus
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    01333 - Door Control Module; Rear Left (J388)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    01334 - Door Control Module; Rear Right (J389)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    01330 - Central Control Module for Central Convenience (J393)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    01320 - Control Module for Climatronic (J255)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    00483 - Control Module for Auxiliary Air Heater
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 11.90 V
    OFF
    OFF
    OFF
    OFF
    OFF
    01332 - Door Control Module; Passenger Side (J387)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    01331 - Door Control Module; Driver Side (J386)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    01520 - Rain and Light Recognition Sensor (G397)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 228
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    00927 - Terminal 30 (Right)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.10 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 38 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD0L1EJI
    Coding: 0013112
    Shop #: WSC 00046 412 40960
    VCID: 3D718FF56471A9A2FE-8068
    Subsystem 1 - Serial number: 6332MSME11066174/
    Subsystem 2 - Serial number: 6342MSME1007652C5
    Subsystem 3 - Serial number: 6352QSME11461F3FN
    Subsystem 4 - Serial number: 6362QSME11497677K
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
    Component: Lenksäulenmodul 636 0070
    Coding: 0000042
    Shop #: WSC 00878 210 88210
    VCID: 74E76AD117BB28EAC1-8020
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K0 920 963 B HW: 1K0 920 963 B
    Component: KOMBIINSTRUMENT VDD 1610
    Revision: V0003000 Serial number: VWZ7Z0F7033264
    Coding: 0003403
    Shop #: WSC 00878 067 57207
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:18
    00771 - Fuel Level Sensor (G)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 229
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:11:57
    Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 H HW: 1K0 907 951
    Component: J533__Gateway H12 0150
    Revision: H12 Serial number: 31001067018AAF
    Coding: 3D3F0B4007000003
    Shop #: WSC 00046 412 851968
    VCID: 2C57B2B18F0B302A59-8078
    7 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:18
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:18
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:18
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:18
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:18
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:19
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:00:24
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 1610
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
    Component: Tuer-SG 005 0964
    Coding: 0000692
    VCID: 387F9EE14B538C8A2D-806C
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.069 H07 1806
    VCID: 356197D55C4171E236-8060
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    000 - -
    Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0202
    Revision: 00020000 Serial number: 00000000000000
    Coding: 019002005103087F2D04840570085FC690FCA0
    Shop #: WSC 00046 412 557056
    VCID: 0305390D42151F52C8-8056
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 951 178
    Component: Neigungssensor 001 0101
    Subsystem 3 - Part No: 1K0 951 178
    Component: Innenraumueberw.001 0101
    1 Fault Found:
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 189
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:00:01
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
    Coding: 0000692
    VCID: 39799BE570599582D2-806C
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No SW: 1K0 035 186 R HW: 1K0 035 186 R
    Component: Radio FO3 021 0014
    Revision: 00021000 Serial number: VWZ7Z2F0017437
    Coding: 0040400
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
    Component: Tuer-SG 005 0912
    Coding: 0000144
    Shop #: WSC 00046 412 1012544
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
    Coding: 0000144
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D51BFB5B41139224E-8078
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    End-------------------------(Elapsed Time: 01:43)--------------------------
    Friday,14,June,2019,20:14:21:00007
    Ross-Tech: Home
    42-Door Elect, Driver -- Status: Malfunction 1010
    Coding: 0000072
    Readiness: N/A
    Revision: 00H11001
    Coding: 0023170
    3 Faults Found:
    Coding: 00038805
    Shop #: WSC 00046
    Coding: 00208933
    Shop #: WSC 00046
    10 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 11.90 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 228
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.10 V
    OFF
    ON
    OFF
    OFF
    OFF
    Coding: 0013112
    Coding: 0000042
    Coding: 0003403
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:18
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 229
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:11:57
    7 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:18
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:18
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:18
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:18
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:18
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:38:19
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 228
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:00:24
    Coding: 0000692
    1 Fault Found:
    00109 - Left Mirror Turn Signal Lamp (L131)
    012 - Electrical Fault in Circuit
    Coding: 099002005103087F2D04840570085FC690FCA0
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 189
    Mileage: 246051 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:00:01
    Coding: 0000692
    Coding: 0040400
    Coding: 0000144
    Coding: 0000144
    1 Fault Found:
    014 - Defective
    End-------------------------(Elapsed Time: 01:40)--------------------------
    i'm getting loads of door error codes which i never had before and thats only since i changed relays around so i mite need to replace a relay some where i think, i think it says terminal 30 so gotta look into that one i think, but as always your help is very greatful
  7. Re: mk5 golf gt tdi 170
    #27
    Jan 2019
    Ross-Tech: Home
    Address 01: Engine
    Revision: --H22---
    Date: 02.07.06
    Flash Status
    Misc.
    Car Info
    VCDS Info:
    Ross-Tech: Home
    19:37:27
    sorry seem to post the last lot twice when i was post this lol, PLUS WHAT IS NTHE CORRECT ENGINE SPEED WHEN CRANKING? MINE WAS SHOWING 257 - 260, JUST RULING OUT STARTER?
  8. Re: mk5 golf gt tdi 170
    #28
    1837 Post(s)
    The BMN has NO fuel pressure monitoring of either of the three pressure stages. Injectors 3&4 have a big problem and the cranking speed must be 280 rpm or higher.
  9. Re: mk5 golf gt tdi 170
    #29
    Jan 2019
    Hi crasher thanks for your reply, so whats wrong with 3&4 injectors then mate? And would they be causing my problem when it cuts out when its warm and wont start up again?
  10. Re: mk5 golf gt tdi 170
    #30
    1837 Post(s)
    They are worn out. The cut out/non start could be the injectors (they have a history of this), there is only one way to find out.
  1. Replies: 4
    Last Post: 21-01-2017, 01:33 PM
  2. Replies: 0
    Last Post: 11-03-2016, 01:40 PM
  3. Replies: 1
    Last Post: 17-12-2015, 06:14 PM
