Thread: vw 5.1 2011 2.0 diesel
Results 1 to 8 of 8
  1. vw 5.1 2011 2.0 diesel
    Jun 2010
    barry vale
    hi guys wondered if there’s any help out there been having problems with my t5 starting it does start ey time but cranks a bit previous to the fault it started on the turn of the key plugged in vagcom and u got camshafts position sensor g 40 again
  2. Re: vw 5.1 2011 2.0 diesel
    1841 Post(s)
    In what respect, implausible or no signal?
  3. Re: vw 5.1 2011 2.0 diesel
    Jun 2010
    barry vale
    no signal it insure it was implausible 4 but can’t be 100%
  4. Re: vw 5.1 2011 2.0 diesel
    1841 Post(s)
    The difference between none and implausible is huge in this case.
  5. Re: vw 5.1 2011 2.0 diesel
    Jun 2010
    barry vale
    it reads
    1 fault found
    4114 camshaft position sensor g40
    p3007 00 (039) no signal
    fault status 00000001
  6. Re: vw 5.1 2011 2.0 diesel
    Jun 2010
    barry vale
    4114 camshaft position sensor g40 no signal p3007 00 (039
  7. Re: vw 5.1 2011 2.0 diesel
    1841 Post(s)
    Private message me your reg so I can look up the part.
  8. Re: vw 5.1 2011 2.0 diesel
    1841 Post(s)
    You have to take the timing belt off to chnage it The sensor is 03L 957 147 A and costs £41.57 from a VW van centre.
  1. A8 2011 3.0 diesel
    By T-CUT in forum A8 - S8 - V8
    Last Post: 04-07-2018, 12:55 PM
  2. Attention Audi A8 2011 4.2 litre Diesel - Transmission Coolant Valve failure
    By MilanB in forum A8 - S8 - V8
    Last Post: 10-01-2018, 08:37 AM
  3. Replies: 0
    Last Post: 01-08-2016, 08:51 PM
  4. Replies: 1
    Last Post: 23-04-2015, 08:48 PM
