Thread: 1.6 DPF problems
  1. 1.6 DPF problems
    Nov 2018
    Tamworth
    22 Post(s)
    Hi all.
    Car has gone into limp mode.
    Local VW dealership is saying the DPF is shot and needs replacing at many £££££'s
    VDCS shows this:
    Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 BC HW: 03L 906 023 D
    Component: R4 1.6l TDI H13 9979
    Revision: --H13--- Serial number:
    Coding: 00114014000500080000
    Shop #: WSC 124697 483 00190
    ASAM Dataset: EV_ECM16TDI02103L906023BC 003014
    ROD: EV_ECM16TDI02103L906023AH_003.rod
    VCID: 68884EB3A2FBA9C736D-803C
    1 Fault Found:
    16848 - Diesel Particulate Filter
    P2458 00 [175] - Regeneration Duration
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 118365 km
    Date: 2019.04.11
    Time: 11:46:43
    Engine speed: 809.25 /min
    Normed load value: 2.7 %
    Vehicle speed: 0 km/h
    Coolant temperature: 88 °C
    Intake air temperature: 50 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 14.118 V
    Unlearning counter according OBD: 40
    Particle filter: soot mass measured-MASS_SOOT_PHY_PF: -3.15 g
    Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 11.64 g
    Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 441 km
    Counter for regeneration time of diesel particle filter-T_INT_RGN_ACT_INI_PF_ENVD_H: 12596.0189 s
    Particle filter: difference pressure-DIP_PF: 0.00 hPa
    Particle filter: offset for differential press.-DIP_PF_AD[0]: -0.08 hPa
    Service regeneration: Release conditions 3-FRF_STATE_RGN: 9
    Readiness: 1 1 0 0 1
    Means very little to me so I'm hoping someone on here can decipher the info - I'll be very grateful.
    Thanks in advance.
    Andy.
  2. Re: 1.6 DPF problems
    1840 Post(s)
    It is showing a negative loading so the first step is fit a new pressure sensor, calibrate and carry out a driving forced regeneration. If that fails, OK it needs a clean but not replacing. Why is the Ash Mass figure missing?
  3. Re: 1.6 DPF problems
    Nov 2018
    Tamworth
    22 Post(s)
    Thanks Crasher.
    I don't know why there isn't an Ash Mass figure. I've only very recently got my VDCS so I just plugged it in and ran a scan. It wasn't configured (if that's the right phrase) to the car.
    I'll be in touch.
    Andy.
  4. Re: 1.6 DPF problems
    1840 Post(s)
    The sensor is £72.26 and to fit and calibrate is £66
  1. Please Help Where do I start?.. Audi a3 S Line Quattro tdi (BKD) problems.. big problems??
    By footychick in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-04-2017, 10:30 PM
  2. Passat 2010 Heater Problems (with climate) & cutting out problems
    By asguk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-10-2015, 11:08 AM
  3. Please Help ignition problems. Well. Let's go with just Problems to be honest.
    By j.topher in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-02-2015, 02:01 AM
