Thread: 1.9 BXE diesel cut-out & not starting - Help please
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: 1.9 BXE diesel cut-out & not starting - Help please
    May 2012
    Everywhere
    308 Post(s)
    Not to mention the exploding BXE engine issue.
  2. Re: 1.9 BXE diesel cut-out & not starting - Help please
    Sep 2009
    Cheshire
    Hmm...
    Don’t go there, as in... been there, done that and got the T-shirt.
    This is on the replacement BXE engine after having previously had a con-rod issue / broken engine issue a while back...
  3. Re: 1.9 BXE diesel cut-out & not starting - Help please
    Dec 2014
    Bedford
    42 Post(s)
    Jack off side up, put it in 4th gear, turn os wheel by hand , can you feel compression on cylinder 4 compression stroke ? If not you have lost compression on that cylinder.
    I would try this first as it is quick cheap and easy.
    Sent from my SM-G970F using Tapatalk
  4. Re: 1.9 BXE diesel cut-out & not starting - Help please
    Sep 2009
    Cheshire
    Hi there,
    Thanks for the advice and suggestion - good idea... not done that yet, but initial thoughts from garage are not thought to be lack of compression as the problem comes and goes.
    It can drive and run perfectly all day and then another time it has this vibration, then it can be fine again.
  5. Re: 1.9 BXE diesel cut-out & not starting - Help please
    Apr 2019
    Just posted this thread and then I read yours. The main electrical wiring harness is easy to see from the front of the engine.
    This post is to inform others if they may be experiencing this issue of their car going to limp mode/shutting down while driving. Approximately 4 months ago, with about 175k miles, I was noticing that the car was shuddering/jerking intermittently. I had recently had my
    timing belt changed, so I thought maybe it was off a tooth. Then I began doing research online and thought it was my MAF sensor. I cleaned it and no change. After more research, I thought it was my DMF as it was knocking and needed to be changed. Changed the DMF, issue still present. I then heard it could be my EGR or DPF. I plugged in an OBDII and no codes were found.
    I went to visit a friend and he did a quick search online and found a post that revealed the problem:
    The main engine wire harness that goes between the engine block and oil filter - was melted against the engine block and was causing a short.
    Here is the link to that post: Passat B6 CBAB engine cut off while driving - Page 2
    Here is a picture of my wire harness:
    The fix: Pulled it away from the block. There was no major compromise of the wiring, so I will likely be adding new heat tape. Since pulling it away from the block, I have not been able to replicate the fault.
    Hope this helps!
  6. Re: 1.9 BXE diesel cut-out & not starting - Help please
    1840 Post(s)
    That is a known issue on the common rail but not the PD
  7. Re: 1.9 BXE diesel cut-out & not starting - Help please
    #17
    Sep 2009
    Cheshire
    Thanks for the suggestions and advice.
    Garage suggested an injector wiring harness beneath the rocker cover.
    The car is at the garage and waiting to hear the findings.
  8. Re: 1.9 BXE diesel cut-out & not starting - Help please
    #18
    Jun 2020
    sheffield uk
    Did you solve the problem?
  9. Re: 1.9 BXE diesel cut-out & not starting - Help please
    #19
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by dazoswfc1867 View Post
    Seems that he did - loom melted and contacting hot engine. Happened to me on my PD where the turbo actuator loom dropped onto the turbo heat shield and started to melt. Engine cut out, hard to start, higher revs, subsequent cut outs, vibration and a crankshaft sensor fault (red herring as it happens). Re-insulated the wires and made sure the loom was fixed in position properly.
  1. Please Help starting problem 1.9 diesel
    By ktmtom in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-08-2016, 09:12 PM
  2. non starting diesel
    By Ryan munslow in forum Golf MK4 - 1999 - 2004
    Last Post: 11-02-2013, 11:10 PM
  3. A4 diesel starting problem
    By timswait in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-04-2012, 05:54 PM
  4. Question poor diesel starting
    By andy good in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-08-2009, 11:06 PM
  5. A6 diesel starting problem
    By Bob Heritage in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-06-2009, 09:36 AM
