Thread: Suspension noise, where to start?
Results 1 to 10 of 11
  1. Suspension noise, where to start?
    Feb 2017
    Preston, UK
    I have a front left rattle but only when changing road surfaces/rough road between 20-60mph. Motorway is fine, and speed humps/bumps at low speeds there's no noise. Definitely just the one side. Everything I've googled seems not to fit (ie it doesn't happen over slow bumps).
    2009 Estate. Any ideas?
  2. Re: Suspension noise, where to start?
    1837 Post(s)
    Usually it is the anti roll bar drop link lower joint.
  3. Re: Suspension noise, where to start?
    Feb 2017
    Preston, UK
    Well I've had it on a lift, and there's nothing obvious.. ..
    But I recently had new discs and pads, so I took the wheel off and the disc isn't screwed to the hub. Could that do it? And where would I get a screw?!
  4. Re: Suspension noise, where to start?
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    The screw is irrelevant when the wheel is bolted on as it holds everything together.
    Mine has a similar rattle noise which I think is the anti-roll bar link as one side was done for the MOT and now it is the other side doing it.
  5. Re: Suspension noise, where to start?
    Feb 2017
    Preston, UK
    Quote Originally Posted by jmurray01 View Post
    Gave all the bars a good tug when on the ramp today and everything seemed solid to the mechanic and myself. Wait for it to get worse I suppose!!
  6. Re: Suspension noise, where to start?
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Well it's a Volkswagen so it'll either mysteriously go away or something will fall off! Life is certainly interesting driving these cars.
  7. Re: Suspension noise, where to start?
    Feb 2017
    Preston, UK
    Droplinks were so cheap I'm going to try one tomorrow anyway.
  8. Re: Suspension noise, where to start?
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by acattanach View Post
    Check your springs carefully - all of them - from top to bottom as sometimes the small coils top or bottom rust through, break off and small pieces end up in the strut cup (front) or wishbone recess (rear) but the springs extend and jam back onto the mounts making them look normal. Also check your steering by rocking it back and forth with the steering lock disengaged to see if there is excess noise / knocking. Might not be the steering rack itself although wear is common but the inner tie rod ball joints. Also with the car on the ground reach behind the wheels and grasp the driveshafts shaking them in all directions to see if any play, there should be virtually none as worn inner cv / tripod joints common especially the OS one which extends from the gearbox on the left hand side of the car to the right hand wheel so noise would appear to be on the NS.
    Let us know if you find anything.
    PS Don't go cheap with the drop links - the TRW ones for example are reasonably chunky but budget ones so much thinner.
    Mad Mitch
  9. Re: Suspension noise, where to start?
    1837 Post(s)
    I fitted a pair of TRW drop links on Mrs Crasher's Polo GTI last week, stopped half the rattle when I am in the car with her, the other is incurable...
  10. Re: Suspension noise, where to start?
    Jan 2012
    10 Post(s)
    87 Post(s)
    Yep - have same annoying chatter coming from my passenger seat
    Mad Mitch
  1. Steering/suspension noise
    By gr2uk in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-02-2019, 03:56 PM
  2. Suspension noise
    By JRL 2W in forum Golf MK7 - 2013 - 2019
    Last Post: 08-09-2013, 10:00 PM
  3. Please Help Suspension noise
    By bw10030 in forum Fabia
    Last Post: 17-02-2012, 07:52 PM
  4. Front Suspension Noise
    By tajgill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-10-2009, 10:45 PM
  5. Please Help suspension noise
    By tiger273 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-12-2008, 09:21 AM
