Thread: ABS problem
  1. ABS problem
    Jan 2008
    Hi, I think I have a problem with a wheel sensor. The ABS seems to be operating all the time if I brake or steer. If I disable the ESP (whatever that is) it's fine but I assume that disables the ABS as well.
    Is this caused by a wheel sensor? If so, how do I tell which one?
  2. Re: ABS problem
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Disabling ESP won't affect ABS.
    You will need a VCDS scan to find out what is wrong.
    Could just be a wheel sensor, but at least it will tell you which one.
  3. Re: ABS problem
    Jan 2008
    Well it does affect the ABS! It's undriveable without switching off the ESP, but it's OK with it switched off as long as I don't brake too hard (if I do the ABS comes on very early and stays on for a few seconds as I drive off).
  4. Re: ABS problem
    Jun 2016
    Glasgow
    Get it scanned and report back.
    Ideally drive it and monitor live data for all wheel speeds.
  1. Please Help 2001 1.9TDI power problem, freezing trip computer and starting problem
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2014, 12:44 PM
  2. Sat Nav problem? Or user problem? Can't select postcode entry.
    By rafletcher in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-09-2012, 10:41 AM
  3. Puzzling coolant temperature problem (not just a sender problem)
    By bartonthesparta in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 06:58 PM
  4. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  5. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
