Thread: Led resistor
  1. Led resistor
    Feb 2017
    Rochester
    Hi guys
    Which resistor would I need for a led license plate light? Trying to install a reversing camera with an led light in it. I can’t find a camera without the led as the light.
    Any information would be great.
  2. Re: Led resistor
    Dec 2018
    newcastle
    • Resistor adapter for licence plate LED or 25 ohm >10 W resistor
    on my cable there is 3 of these hope this helps
  3. Re: Led resistor
    1836 Post(s)
    You may be able to code it out of the central electrics unit.
  4. Re: Led resistor
    Jul 2017
    Ipswich UK
    Resistors are only really suitable for small panel light type LEDs, however it sounds like you are talking about the LED on the camera which is used to illuminate behind the car - in which case I would expect it to be ready to connect to the normal car 12v. Why do you think you need a resistor? If the spec does say you do need a resistor then we need to know what the specification of the LED is (voltage and max current) before you can size a resistor or a constant current driver. I'll be interested to hear what the exact situation is.
  1. What resistor
    By royclark in forum Home Tech Shed
    Last Post: 29-10-2015, 02:48 PM
  2. Question burnt out resistor?
    By RudeEffects in forum Home Tech Shed
    Last Post: 13-09-2015, 11:20 AM
  3. Resistor Value
    By Cpt Shed in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-06-2011, 08:23 PM
  4. Resistor T4 Cooling fan
    By glowplug in forum The Commercial Range
    Last Post: 29-12-2009, 09:22 PM
  5. Please Help Resistor Unit???
    By Windybear in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 10-10-2009, 11:51 PM
