Thread: Upper Track Control Arm Bushes Split?
  1. Upper Track Control Arm Bushes Split?
    Oct 2009
    Malvern
    Just got my Audi A4 back from its MOT today, it did PASS but with advisories on Upper Control Arm, Bushes starting to split?
    I asked how easy a job this was to replace the Bushes but he said it's far easier just to replace the whole arms?
    Just looked on Mr. Auto for new parts, they don't seem too expensive (about £29.00 per arm) and they seem easy to change? But where does one get new Bolts from? as they're not listed, and the garage said these normally shear off in trying to remove them :-( Also are the two arms on each side the same? as there's 4 of them in total.
    Audi A4 3.0TDI Q SE Lava Grey + B&O, Audi Drive Select, Sports Seats, Sun Roof, DVD Sat Nav Plus, Blue Tooth Phone Prep, Audi Hill Assist, Rear Parking Aid, Electric Seats, Light Pack, Audi Audio Interface, MMI etc... and 4 Halfords Bulbs lol....
  2. Re: Upper Track Control Arm Bushes Split?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Research this job thoroughly before tackling it at home.
  3. Re: Upper Track Control Arm Bushes Split?
    Oct 2009
    Malvern
    From what I can see it's simpler just to purchase new arms and simply swap them over? it's only a few bolts to undo? or is there tension on these arms? Did anyone change theirs at home? Obviously, I would source some new bolts as well.
  4. Re: Upper Track Control Arm Bushes Split?
    Sep 2008
    6 Post(s)
    Quote Originally Posted by Pauls898 View Post
    First off, buy decent parts, so Lemforder or Meyle HD. You'll also need new pinch bolts. As mentioned, do your research as the pinch bolt removal will determine whether the job proceeds or not.
    The pinch bolt needs to be thoroughly clean, wire brush exposed threas, and liberally spray with penetrating oil such as PlusGas a good week before attempting the job.
    I've tried most methods, but with nut off, get a bar and socket on it and rotate slightly, while spraying liberally. I've read if the pinch bolt head shears, put the nut back on and pack with washers.
    With the the new upper arms on, only torque once the car is down or you'll stress the bushes.
    2016 BMW i3 REx (25k)
    2012 A4 Allroad Quattro 2.0 TDI (55k)
    2003 A2 1.4 TDI SE (166k) sold
    2001 B5 A4 2.5 TDI Avant Quattro Sport, (173k), sold
    1995 B4 80 1.9 TDI Avant SE, (175k), sold
  1. Question Polo 9n track control arm bushes
    By Psion in forum Polo - Derby - Lupo - Fox
    Last Post: 05-04-2018, 08:58 AM
  2. Upper Control Arms ?
    By Lewis-Oddie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-05-2014, 02:53 PM
  3. Question Track Rod End Bushes
    By venetian-red in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-12-2013, 07:34 PM
  4. Rear Suspension Upper Control Arm (or Bushes) '99 Quattro Avant 2.5tdi
    By aliw in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-05-2012, 04:59 PM
  5. disconnect abs sensor? remove/split track rod end?
    By shaiboy_uk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-03-2008, 08:24 PM
