Thread: Help 2004 1.9tdi a4 intermittent starting issue
Results 1 to 10 of 12
  1. Help 2004 1.9tdi a4 intermittent starting issue
    Apr 2019
    Northern Ireland
    At my wits end..... I have a 2004 1.9tdi a4 sport , 110000 miles With a very intermittent starting issue so far I have change fuel/temp sensor , fuel
    Filter, gasket on tandem pump and checked the timing and still no joy as to fixing the problem , I have left the car to mechanic and electrician to try to help detect the problem both of which couldnít get the car to misbehave after 2 weeks I collected it drove it home came out the next morning and boom hard to start ,....... once the key is in the ignition it will turn over and youíd think it is going to start then it misses amd winds over for a minute and eventually starts but struggles like itís building fuel pressure Once it starts it will start perfect all day unless you leave it sitting over night very frustrating as the car drives perfect engine is smooth with no smoke and loads of power very economical, any help appreciated 😁
  2. Re: Help 2004 1.9tdi a4 intermittent starting issue
    scotland
    39 Post(s)
    Sounds like the fuel pressure is doing back over night. I'd check the tandem pump gasket and also the fuel filter is sealed properly.
    Sent from my ANE-LX1 using Tapatalk
  3. Re: Help 2004 1.9tdi a4 intermittent starting issue
    Apr 2019
    Northern Ireland
    I changed the tandem pump gasket amd a new filter , also but a new pump
    For the tank but the auto spark said there was nothing wrong with the one in the car
  4. Re: Help 2004 1.9tdi a4 intermittent starting issue
    Apr 2019
    Northern Ireland
    Also it would
    Seem if the car is left stationary it will start fine the next morning hence why mechanic and auto spark could t get fault to re occur they both left the car in there work shop starting every Morning but not moving it and it didnít fail, but once I picked it up amd drove it for over an hour to my house parked overnight then it struggles to start itís really strange
  5. Re: Help 2004 1.9tdi a4 intermittent starting issue
    Jan 2009
    Birmingham
    19 Post(s)
    Is it parked on a slope at night?
  6. Re: Help 2004 1.9tdi a4 intermittent starting issue
    scotland
    39 Post(s)
    Quote Originally Posted by arman123 View Post
    If it is parked on a slope, trying parking it the opposite way round next time.
  7. Re: Help 2004 1.9tdi a4 intermittent starting issue
    Jan 2009
    Birmingham
    19 Post(s)
    Quote Originally Posted by calum View Post
    if it starts facing down hill then fit a non return on the fuel line
  8. Re: Help 2004 1.9tdi a4 intermittent starting issue
    Apr 2019
    Northern Ireland
    No different up hill or down ☹️
  9. Re: Help 2004 1.9tdi a4 intermittent starting issue
    Apr 2019
    Northern Ireland
    And it’s avb engine code
  10. Re: Help 2004 1.9tdi a4 intermittent starting issue
    Jan 2009
    Birmingham
    19 Post(s)
    Have you got access to Vcds to scan for fault codes
  1. Intermittent starting issue - Polo 1.4 TDi
    By dave_tp in forum Polo - Derby - Lupo - Fox
    Last Post: 23-01-2019, 11:56 AM
  2. Intermittent starting issue
    By bigmikeyoyo in forum Golf MK5 - 2004 - 2009
    Last Post: 19-08-2016, 07:49 PM
  3. Please Help 2004 1.9 tdi engine code bkc. Intermittent starting issues
    By Mickyroo in forum Golf MK5 - 2004 - 2009
    Last Post: 29-05-2015, 10:03 PM
  4. Please Help 2004 A4 B6 Avant 2.0 fsi intermittent starting problem
    By decker39 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-03-2014, 02:26 PM
  5. Intermittent starting issue
    By Todri in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-05-2011, 05:54 PM
