Thread: Forced dpf regent won’t work because of parking brake fault
  1. Forced dpf regent won’t work because of parking brake fault
    Sep 2008
    Highlands
    12 Post(s)
    Hi All
    my my step son has a 2008 2.0 TDS b8 a4
    his dpf light is on in the dash .
    i plugged in vcds and tried to doa forced regent to clear it but it wouldn’t go because of a fault with electric handbrake
    03182 clutch position sensor. Fault to ground.
    the electric handbrake is working fine.
    can I bypass the fault in vcds to force the regen ?
    What about the clutch position sensor fault ?
    any help much appreciated
    vin
  2. Re: Forced dpf regent won’t work because of parking brake fault
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Have a look at this link :-
    https://www.audi-sport.net/xf/thread...-fault.233505/
    Unfortunately the wiring diagram is for a different model, but the principle should be the same & could still be identical.
    So the clutch position module interconnects to the PBM for obvious reasons.
    You could probably frig the condition on the interconnect wire between the two modules to get rid of the PBM fault code.
    The fault could also reside in the PBM module itself.
  1. Question Parking brake fault
    By hippo in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-06-2017, 11:46 PM
  2. Parking brake fault - again
    By DSGboy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-04-2016, 09:35 PM
  3. Question: Parking Brake Auto Release/Hill Hold assist doesn't work in 1st Gear
    By Pat Cronin in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 08-07-2015, 08:02 PM
  4. Please Help Parking Brake Fault
    By EGoodier in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2011, 01:05 AM
  5. Parking Brake Fault
    By podwin in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2011, 05:06 PM
