Thread: Fog Lights DRL
  1. Fog Lights DRL
    Everywhere
    Hi Guys,
    My Passat is currently set to have the fog lights com on as drl’s however when I put my headlights on dip or full I cannot switch on fogs if needed.
    Can anyone advise the vcds settings to select back to normal.
    I’ve tried but just can’t get it right.
    TIA
    Sent from my iPhone using Tapatalk Pro
  2. Re: Fog Lights DRL
    Sep 2015
    North West
    I think what you describe is normal.
    Unless you have the three position headlight/foglight switch (off, rear, front) rather than the two position switch like I have (off, rear) then you don't have front fogs - just DRLs.
    I wanted to do the same but when I've looked into it, it's an expensive conversion requiring the proper switch, wiring and new light units.
    I'm considering some old school aftermarket lights wired to one of the switch blanks in the gear stick console.
    Sent from my SM-G970F using Tapatalk
  3. Re: Fog Lights DRL
    Everywhere
    I was wondering was that the case, my switch is very basic.
    Off - parking lights - headlights, then pull out for fog.
    When headlights on, drls are off and only rear fog operates with pulling out selector.
  4. Re: Fog Lights DRL
    Sep 2015
    North West
    That's the same as mine. Unfortunately it's DRLs only for us.
    1 1 0
  5. Re: Fog Lights DRL
    Everywhere
    Cheers for the info
  1. Question vw polo 1.2 twist number plate lights n dashboard lights not working
    By gauchosanto in forum Polo - Derby - Lupo - Fox
    Last Post: 29-09-2017, 07:03 PM
  2. Question Coming home lights AUDI S3 - Query xenon to fog lights (information inside)
    By A6-MO in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-02-2013, 02:28 PM
  3. Please Help All interior lights and door lights stopped working in my Sharan 1.9 TDi (Nov 01 New Shape)
    By di4charles in forum Touran - Sharan - Caravelle
    Last Post: 09-01-2013, 01:50 AM
  4. Please Help Enabling Coming Home lights in VCDS (no auto lights fitted)
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-07-2011, 09:42 PM
  5. ABS, Glow plug, Traction control lights Flashing and no brake lights
    By bbq365 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2011, 06:15 PM
