Thread: after market xenon
Results 1 to 10 of 11
  1. Question after market xenon
    May 2008
    question?
    can / should i install 55w can bus hid xenon's kit in my dip beam and or main beam.
    or 35w.
    thanks for any input!
  2. Re: after market xenon
    108 Post(s)
    1816 Post(s)
    Illegal and an instant MOT failure.
  3. Re: after market xenon
    May 2008
    thanks for your reply crasher.
  4. Re: after market xenon
    May 2008
    crasher ,
    can i upgrade to xenon's from a newer model?
  5. Re: after market xenon
    108 Post(s)
    1816 Post(s)
    Yes you are allowed to fit the OE system which was optional but it is a hugely complex job as you need to install the suspension height detection system if yours does not have it, Private Message me your reg and I will see what sort of a job it is.
  6. Re: after market xenon
    108 Post(s)
    1816 Post(s)
    The car has headlight wash which is a prerequisite for HID lights and self levelling headlights with front and rear suspension height detection, these are the two main stumbling blocks. Assuming you want to keep this simple and not go for cornering lights you need a pair of headlights from a 6 or 8 cylinder model so part numbers 4L0 941 029 D and 030 D, £730.27 each from Audi..... these were used from 2007>2009 but you can get the by Valeo.
  7. Re: after market xenon
    May 2008
    thanks for your replys crasher.
    tve looked at the pdfs you sent, but a bit over my head!
    ive found this adapter. https://www.kufatec.com/de/alle-prod...di-q7-4l-40528
    what do you think?
    ive noticed two extra cables in the kit,but cant see where these connect.
  8. Re: after market xenon
    108 Post(s)
    1816 Post(s)
    That should work, the connectors will plug into a housing but you should get instructions.
  9. Re: after market xenon
    May 2008
    cheers crasher,
    just checked my connector on the car to the headlights.
    its a ten pin connector,but only four wires used?
    will this matter?
    cheers.
  10. Re: after market xenon
    108 Post(s)
    1816 Post(s)
    Yes it will, what are the wire colours and at which socket point numbers?
  1. B7 A4 fitting aftermarket xenon headlights to non xenon car
    By ralosc in forum Body Work, Body Styling and Body Kits
    Last Post: 05-03-2017, 05:09 PM
  2. Question about headlights: Xenon or not Xenon
    By jackms in forum Alhambra
    Last Post: 31-08-2016, 11:51 AM
  3. Please Help Single Xenon to bi-xenon conversion. Help...
    By vw1997 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-04-2013, 09:20 PM
  4. Xenon Headlights to none OEM Xenon Cabriolet
    By brooksyboy in forum Chat - Anything with wheels
    Last Post: 12-10-2009, 11:48 PM
  5. Headlamps Xenon or Bi-xenon
    By scootermap in forum Audi A4 - Archive Topics
    Last Post: 20-01-2008, 08:51 PM
