Thread: Rattle from front possibly brake pads? Passat B7 2012
Results 1 to 8 of 8
  1. Rattle from front possibly brake pads? Passat B7 2012
    Dec 2015
    Scotland
    11 Post(s)
    I replaced my front pads and discs last week for trw Gdb1550 ones (which I bought as I thought they were close to OEM and have had good results from trw over pagid and textar.
    Anyway did 300/400 miles last week then had mot and all fine, car had one advisory on a lower Bush.
    We drove 150 miles on holiday and I’ve noticed every time I go over a bump there is a fairly audible rattle, and if I brake it stops.
    I took the wheel off and checked everything, the bushes all look ok and indeed a little perished but nothing that looks like it’s worn enough for the rattle I’m getting! The calliper is on tight with the guides and I fitted new spring retainers!
    I’m really flummoxed as the passenger side is ok I’ve seen a few mentions of pad rattle is this possible? Is there any way I can test - a wedge between the pad guides and pad then do a short run???
    Audi A6 2008 Saloon Sline 2.0 Tdi BRE
    Vw Passat B7 1.6 tdi 2012 estate
    Previously - 2008 1.6 tdi Mini, 2006 Mazda Mx5 1.8, 2002 Vw Golf 1.9 tdi SE, 2010 Bmw 318d Msport, 1992 Porsche 944 2.5 turbo, 1986 Porsche 944 2.5 NA, 1984 Porsche 944 2.5 NA
  2. Re: Rattle from front possibly brake pads? Passat B7 2012
    1841 Post(s)
    I have had this a few times now, the caller carriers wear and the pads start to kick about. I have even known people to weld a blob into the pad groove and file it to match. Possibly excessive salt and environmentally friendly cast iron and surface treatments?
  3. Re: Rattle from front possibly brake pads? Passat B7 2012
    Dec 2015
    Scotland
    11 Post(s)
    Thanks for the reply! To be honest I did hit the guides quite hard with the wire wheel and was wondering if that was a bad move, it was rusty and ironically I assumed it could prevent them from sliding smoothly!
    What a pita!
  4. Re: Rattle from front possibly brake pads? Passat B7 2012
    Dec 2015
    Scotland
    11 Post(s)
    Just did a quick check the pad carriers are stupidly expensive £80?!
    3C0615125A
  5. Re: Rattle from front possibly brake pads? Passat B7 2012
    1841 Post(s)
    Err no, genuine they are £224.94. They are made by ATE - Brakethrough Technology, their number 11.0230-0131.1
  6. Re: Rattle from front possibly brake pads? Passat B7 2012
    Dec 2015
    Scotland
    11 Post(s)
    Haha brilliant thanks I’ll have a hunt about!! The ones I saw were made by Trw, they were maybe for the other caliper / brake set up!
  7. Re: Rattle from front possibly brake pads? Passat B7 2012
    1841 Post(s)
    The 3C0 615 125 A carriers are made by ATE
  8. Re: Rattle from front possibly brake pads? Passat B7 2012
    Dec 2015
    Scotland
    11 Post(s)
    Well good news it turned out to be an easy fix (for now!?) on the inboard pad the 3 leg retaining clip had 2 bent legs once I straightened these out and exaggerated the bend to provide more retention all is perfect! Can’t believe one loose pad was making such a loud noise!
    1 1 0
  1. Anti-Rattle clips for front brake pads
    By Steve_K in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-07-2013, 08:46 AM
  2. front brake pads vw passat tdi 2007
    By sharantdi in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-04-2010, 01:25 PM
  3. Installing front brake pads 2003 Passat 130 TDI
    By Ryanroo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-01-2010, 06:36 AM
  4. Passat - Change Front Brake Pads
    By csopho in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-05-2008, 04:28 PM
  5. Fitting front Passat brake pads
    By ansumstan in forum Passat - Archive Topics
    Last Post: 04-12-2006, 12:30 AM
