Thread: 5301 - Throttle Actuator Control Circuit- Fault ---PLEASE PLEASE HELP
  1. 5301 - Throttle Actuator Control Circuit- Fault ---PLEASE PLEASE HELP
    Jun 2006
    Hi All,
    I have been having some trouble with my car. I got a check light on and read the code.
    P2100 00 [100] - Open Circuit
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 242604 km
    Date: 2019.04.06
    Time: 18:34:19
    Engine speed: 755.50 /min
    Normed load value: 29.8 %
    Vehicle speed: 0 km/h
    Coolant temperature: 83 °C
    Intake air temperature: 36 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 13.660 V
    Unlearning counter according OBD: 40
    Crankshaft speed (RPM): 755.5 /min
    Vehicle speed: 0.00 km/h
    Thr Vlv r: 39.48 %
    Ambient temperature: 17.5 °C
    Intake air temperature: 36.1 °C
    Throttle valve output stage: 60.51 %
    Vehicle voltage terminal 30: 13660 mV
    5307 - Throttle Valve Actuator Control System
    P2101 00 [039] - Malfunction
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 242604 km
    Date: 2019.04.09
    Time: 19:13:40
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Coolant temperature: 8 °C
    Intake air temperature: 9 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 10.780 V
    Crankshaft speed (RPM): 0.0 /min
    Thr Vlv r: 100.00 %
    Ambient temperature: 9.6 °C
    Intake air temperature: 9.6 °C
    Throttle valve output stage: 5.00 %
    Vehicle voltage terminal 30: 10780 mV
    I had a read and thought that it was the throttle body or ASV. I changed it for a new one as when i opened it up all the cogs have been warn away and it was slipping like mad.
    However, i still can not clear the fault code on VCDS. I read that there should be a fuse that probably gone. I can not find any fuses gone, I check with a multi meter. Where is these fuse ?
    Also, how can i activate the throttle body in VCDA to see if it is working and what blocks can i check for it status?
    This whole thing have caused my DPF to block and i cant regen in VCDS. (I hope if i clear the fault it will regen)
    PLEASE HELP
  2. Re: 5301 - Throttle Actuator Control Circuit- Fault ---PLEASE PLEASE HELP
    1837 Post(s)
    I can see it is a diesel but the engine is a......?
  3. Re: 5301 - Throttle Actuator Control Circuit- Fault ---PLEASE PLEASE HELP
    Jun 2006
    It is a CCWA. 240BHP.
    Thanks for any help.
  4. Re: 5301 - Throttle Actuator Control Circuit- Fault ---PLEASE PLEASE HELP
    1837 Post(s)
    That is the right hand bank 1 V157 motor, if it was a power failure you would have a code from the bank 2 V275 so you need a new bank 1 manifold but as the other is likely to fail, it makes sense to do both 059 129 711 DC and 059 129 712 CA, £656.12 retail inc VAT each.
  5. Re: 5301 - Throttle Actuator Control Circuit- Fault ---PLEASE PLEASE HELP
    Jun 2006
    Thanks for the reply.
    what makes you think it is the inlet manifold? I run output tests and they activate. I also confirmed all wiring today.
    Bank 1 being drivers side?
    i have just ordered a rebuild kit for the manifolds.
    i am still convinced it is the ASV also causing me a problem. I now think the new one I have got (Cheep eBay job) is faulty. I plugged the original one in gave it a bang and wiggle and can hear the motor activate so know the wiring is good.
    thanks for the input.
  1. P2100 Throttle actuator control motor circuit open FAULT MIL LIGHT
    By petrolhead63 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-09-2018, 10:06 PM
  2. fault code help Intake Manifold Flap and Throttle Actuator Control System
    By danny851 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-04-2016, 06:05 PM
  3. Throttle Actuator Control System...vcds
    By flange101 in forum VCDS - Help Requests
    Last Post: 03-05-2014, 08:34 PM
  4. Question Throttle actuator. Control module performance
    By steve1950 in forum Golf MK5 - 2004 - 2009
    Last Post: 31-08-2013, 02:16 PM
  5. Please Help Throttle Valve Actuator Module (J338): Motor Circuit: Signal High
    By jasonmking in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-04-2013, 02:58 PM
