Thread: Camshaft Sensor probelms
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Camshaft Sensor probelms
    Apr 2019
    Rochester
    Problem sorted.
    My fitting of new ignition leads caused the problem. I didn't tuck one of the leads into the clip array, and was resting on the cam sensor wire. The electrical pulses on the ignition lead obviously interfered with the cam sensor wire. Something I didn't realise.
    Now tucked in properly, the car is good
  2. Re: Camshaft Sensor probelms
    Jun 2020
    Mauritius
    Hi Guys,
    Am new to the forum. However need some help ( Audi S3 Year 2014 )
    Having Fault Code
    P138800 CTRL MODULE FAULTY
    P11A200 CAMSHIFT ACTUATOR 'A' CYLINDER 1
    P11AA00 CAMSHIFT ACTUATOR 'A' CYLINDER 3
    P11AE00 CAMSHIFT ACTUATOR 'A' CYLINDER 4
    P11A600 CAMSHIFT ACTUATOR 'A' CYLINDER 2
    P11A400 CAMSHIFT ACTUATOR 'B' CYLINDER 1
    P11AC00 CAMSHIFT ACTUATOR 'B' CYLINDER 3
    Already Check the values from the Camshift and they are all giving the same values.
    Checked the Wiring from the Camshift to the ECU plugs and there is continuity.
    The Car been sitting for 2 months during the confiment period and drove 1 day without any problem but the issue came on the next day after a 'pop' from the exhaust.
  3. Re: Camshaft Sensor probelms
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Quote Originally Posted by Shahnawaaz View Post
    Hi Guys,
    Having Fault Code
    There are to many 00's in those error codes.
    You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  4. Re: Camshaft Sensor probelms
    Jun 2020
    Mauritius
    Quote Originally Posted by Keithuk View Post
    What is strange is that I cannot get Values from live data on the diagnostic. It’s like the ecu is not receiving a particular signal.
  5. Re: Camshaft Sensor probelms
    1837 Post(s)
    We need a proper VAG specific code read scan posting properly preferably using VCDS but the first thing I would check with all these codes is take the sump off and check for oil pump pickup contamination.
  6. Re: Camshaft Sensor probelms
    Aug 2020
    Tunisia
    Can you explain me more what does this message means of @Stinca please? It is wiring probleme? Cuz i have the same probleme. This is his message (My fitting of new ignition leads caused the problem. I didn't tuck one of the leads into the clip array, and was resting on the cam sensor wire. The electrical pulses on the ignition lead obviously interfered with the cam sensor wire. Something I didn't realise.)
  1. Camshaft position sensor / sender (G40 Hall sensor) replacement Audi A6 2.0 BRE
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2016, 02:26 PM
  2. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  3. Please Help Camshaft sensor
    By Stoddiegal in forum Bora - 1998 - 2005
    Last Post: 13-11-2010, 08:59 PM
  4. Question Camshaft sensor
    By MOUSE7 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-10-2009, 01:21 PM
  5. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
