Thread: 2008 2.0 tdi 170 cranks but won't start
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 53
  1. Re: 2008 2.0 tdi 170 cranks but won't start
    #11
    Feb 2019
    West Yorkshire
    14 Post(s)
    Thanks for the replies guys.
    I'll whip the starter out and check it over.
    I'll be back in a couple of days when I've had chance to do it and let you know 👍
  2. Re: 2008 2.0 tdi 170 cranks but won't start
    #12
    Feb 2019
    West Yorkshire
    14 Post(s)
    Afternoon guys,
    So I pulled the starter and the brushes were knackered. Replaced those for 15 and it's like new 👍
    Car cranks beautifully but wouldn't start.
    From looking through this forum I saw alot of issues with injector seals so I got new ones for 35 and fit them.
    The car now starts but doesn't sound great, still idles at 1200rpm and sounds like it's misfiring.
    Did a readout with OBDeleven and injector 2 and 3 has implausible signal. I was so careful with the loom but I know they're really brittle as they're sat in hot oil.
    As the loom is the only wiring to the injector I've touched it must be that so I'll have to buy a new one and replace it.
    Anyone know how much it will be and Where's bets to buy it?
  3. Re: 2008 2.0 tdi 170 cranks but won't start
    #13
    Jan 2012
    Rustington, West Sussex UK
    46 Post(s)
    Darkside Developments do them 110 + vat + delivery
    Genuine VW Injector Wiring Loom for VW 2.0 16v TDI PD Engines - 03G 971 033 L
    Some genuine on ebay for less so slightly cheaper if you have a search for the 03G 971 033 L part number.
  4. Re: 2008 2.0 tdi 170 cranks but won't start
    #14
    Feb 2019
    West Yorkshire
    14 Post(s)
    Some genuine on ebay for 114.99 so slightly cheaper.
    Ouch. Cheers Mitch I'll have a check over this one see if it's a loose connection and failing that I'll order one. Any special tools required for fitting it through the head?
  5. Re: 2008 2.0 tdi 170 cranks but won't start
    #15
    Jan 2012
    46 Post(s)
    Yep a special 3 pronged socket but a 3 to 4 foot piece of rope or parachute cord can be a good substitute to make a 'rope coil socket'. The loom connector is in 3 parts, outer ring that holds the pin connector in place with red plastic locking 'pin', inner collar that needs the special tool, then the loom connector itself that fits through the cam bearing frame hole retained with a metal 'U' clip on the inside wall.
  6. Re: 2008 2.0 tdi 170 cranks but won't start
    #16
    Feb 2019
    West Yorkshire
    14 Post(s)
    OK mate thanks for that. Fingers crossed I've just not plugged it in right and I won't need to do it.
  7. Re: 2008 2.0 tdi 170 cranks but won't start
    #17
    Jan 2012
    46 Post(s)
    Quote Originally Posted by Kyle_471 View Post
    I've a great engine workshop manual in PDF if you want it - PM me your email address and I'll send it over.
  8. Re: 2008 2.0 tdi 170 cranks but won't start
    #18
    Feb 2019
    West Yorkshire
    14 Post(s)
    Awesome! Will do.
    I've just been out before it got too dark, pulled the connector off 2 and 3. Checked the wires which look good from what I can see and I've cleaned the connections before putting back.
    Cleared the codes and started the car which took a while.. The codes haven't returned but it still sounds shocking and seems like its misfiring.
  9. Re: 2008 2.0 tdi 170 cranks but won't start
    #19
    Jan 2012
    46 Post(s)
    Awesome! Will do.
    Have you checked the loom behind the cam cover as it occasionally drops onto the turbo heat shield and melts causing shorts and weird running / unrelated fault codes.
    Mad Mitch
  10. Re: 2008 2.0 tdi 170 cranks but won't start
    #20
    Jan 2012
    46 Post(s)
    Also I clean my EGR Valve, Anti Shudder Valve unit ('throttle body' to use its incorrect terminology on a diesel) and intake manifold every 50k as they do gunk up with a soot paste over time. Mine has the original factory fitted intake parts which are still good at 215k - the regular clean seems to extend their life and keeps them freely moving. Diesel filter change every 10k as they are easy to do and the parts cheap (I buy several at a time when on offer).
    Mad Mitch
  1. O7 2.0 tdi A4 cabriolet cranks but won't start!
    By maggotrunner in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-06-2017, 08:42 PM
  2. Please Help 6n2 cranks but wont start
    By mrg123 in forum Polo - Derby - Lupo - Fox
    Last Post: 10-10-2016, 05:52 PM
  3. Question Audi A6 2.7T cranks but won't start
    By eejit in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-08-2015, 11:06 PM
  4. Cranks but won't start
    By thevagcr in forum Golf MK4 - 1999 - 2004
    Last Post: 30-07-2012, 03:24 AM
  5. Engine cranks but will not start
    By Seat Driver 1 in forum Alhambra
    Last Post: 22-10-2011, 09:36 PM
