Thread: 2008 2.0 tdi 170 cranks but won't start
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 59
  1. Re: 2008 2.0 tdi 170 cranks but won't start
    #21
    Feb 2019
    West Yorkshire
    14 Post(s)
    I cleaned the EGR and 'throttle body' a few weeks ago. Didn't do the intake manifold so I guess that will need doing too. They were crammed full of soot.
    Diesel filter was done at the same time 👍
    I'll have a look at the wiring to make sure too. Cheers
  2. Re: 2008 2.0 tdi 170 cranks but won't start
    #22
    Feb 2019
    West Yorkshire
    14 Post(s)
    Slight update, for the worse...
    Checked the wiring, nothing looked to be melted or out of place. Wanted to see if the injector fault came back so I started the engine which needed a jump start.
    I now have what sounds like a tractor engine that almost cuts out and there seems to be smoke coming from the turbo area..
    I can't believe how bad this has got now.. Only bought the car a few months back and regretting it massively. Looks like I'll be on the train to work again this week.
    Besides pulling the injectors and sending them for testing somewhere, replacing the loom and having all the timing checked I don't know what else to do.
    Trouble is, if the injectors are tested they'll probably say they've had it and my only option then is recon ones. New are 500 each and the car was only 2,800.
  3. Re: 2008 2.0 tdi 170 cranks but won't start
    #23
    Feb 2019
    West Yorkshire
    14 Post(s)
    So I now have P1266 and P1270 for injector 3 and 4.
    I've also done some research and it turns out the seimens pd injectors can't be tested or reconditioned?! 🤬
  4. Re: 2008 2.0 tdi 170 cranks but won't start
    #24
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by Kyle_471 View Post
    Course they can - I've seen them tested, dismantled, internal parts replaced, reassembled and retested in a German workshop many years ago a year or two after they found out they were flawed and the original design failing. They are fairly intricate inside and the process was fascinating to see first hand. Not tried it myself with a Siemens unit injector but I have had a common rail Bosch one apart and back together again.
    Just to add the original issue was an internal short to the injector casing which means the internals have to be replaced with the improved design. The outer casing remains unchanged as far as I know.
    Mad Mitch
  5. Re: 2008 2.0 tdi 170 cranks but won't start
    #25
    Feb 2019
    West Yorkshire
    14 Post(s)
    Afternoon Mitch,
    Can you recommend anywhere that reconditions them? The few local places all say they're unable.
    "We cannot test or repair. Nobody can they are main dealer only."
    That's the response to one of my emails.
  6. Re: 2008 2.0 tdi 170 cranks but won't start
    #26
    Jan 2012
    10 Post(s)
    87 Post(s)
    Afternoon Mitch,
    The reason why most workshops can't refurb the Siemens is that Siemens / VAG wouldn't supply the necessary parts to allow the injectors to be remanufactured creating a monopoly where they could charge stupid money even for the refurbished version let alone the new units. Some since the original issue have gained approval from Siemens to be able to remanufacture them but they are few and far between.
    Give TT Auto (TT Automotive - Diesel system specialist - Experts in diesel pumps, diesel injectors, petrol injection, repairs and servicing.) a call in Loughborough as they handle pretty much all the major brands including Siemens VDO which are refused by some. Otherwise it might have to be used units from somewhere as long as you get the right part number and not the faulty ones (there's some in circulation still of that I'm sure). Mine replaced via the VW campaign for free along with the loom that suffers due to the shorting also, have passed 120k mileage and still looked good when I pulled them for a seal change and clean around 20k or so ago.
    Also give Diesel Bob (UK), http://www.dieselbob.co.uk, who merged with Ribble Valley Diesels a call as they might be able to give you an idea as to whether the engine can use Bosch unit injectors instead of the Siemens and how much work / cost is involved. They state they do not refurb Siemens VDO as there is a risk that the fault would not be removed and the damage as a result severe. Only Siemens approved businesses should be considered.
    Perhaps Crasher will read this and add his professional expertise on this subject as he is in the trade.
    Mad Mitch
  7. Re: 2008 2.0 tdi 170 cranks but won't start
    #27
    Feb 2019
    West Yorkshire
    14 Post(s)
    Just out of curiosity what injectors did you have? Do vw still replace them if they've not been done?
    I've been looking into the bosch idea but not sure how viable it is.
    Cheers again
  8. Re: 2008 2.0 tdi 170 cranks but won't start
    #28
    Jan 2012
    10 Post(s)
    87 Post(s)
    The 170 injectors are said to be slightly different and have a part number of 03G 130 073 T whereas the 140, commonly a BKP engine, is part number 03G 130 073 S.
    Mad Mitch
  9. Re: 2008 2.0 tdi 170 cranks but won't start
    #29
    Feb 2019
    West Yorkshire
    14 Post(s)
    03G130073T are those the ones that should of been replaced? Those are what I have.
    I might give vw a call tomorrow and see what they say
  10. Re: 2008 2.0 tdi 170 cranks but won't start
    #30
    Jan 2012
    10 Post(s)
    87 Post(s)
    No they will be the replacements. The faulty ones end in D or M which means the car has had the recall done.
    Mad Mitch
  1. O7 2.0 tdi A4 cabriolet cranks but won't start!
    By maggotrunner in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-06-2017, 08:42 PM
  2. Please Help 6n2 cranks but wont start
    By mrg123 in forum Polo - Derby - Lupo - Fox
    Last Post: 10-10-2016, 05:52 PM
  3. Question Audi A6 2.7T cranks but won't start
    By eejit in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-08-2015, 11:06 PM
  4. Cranks but won't start
    By thevagcr in forum Golf MK4 - 1999 - 2004
    Last Post: 30-07-2012, 03:24 AM
  5. Engine cranks but will not start
    By Seat Driver 1 in forum Alhambra
    Last Post: 22-10-2011, 09:36 PM
