Thread: Injectors issues? Rough idle + black smoke puff with knock sound on crank engine start
  1. Thumbs up Injectors issues? Rough idle + black smoke puff with knock sound on crank engine start
    Jan 2019
    London
    Sorry to bother you guys. Just wanted some of your opinions on what could be the reason for the rough idle. I've recently changed the engine mounts thinking that could be the culprit. As a result, the shake has reduced considerably, however sometimes the car will go in a rough shake, and I feel like this happens every time there's a knocking sound on crank engine start. I will get a puff of black smoke soon after the crank too.
    I did a VCDS on the injectors, apparently from what I understand the values are a bit high than normal, could this be the reason?
    What should I do?
    Audi A3 8PA, 1.9 TDI, 06, 175k miles
    Any ideas/opinions are highly appreciated.
  2. Re: Injectors issues? Rough idle + black smoke puff with knock sound on crank engine start
    Mar 2017
    Nottingham
    9 Post(s)
    Have a look at your torsion value as well
  3. Re: Injectors issues? Rough idle + black smoke puff with knock sound on crank engine start
    1837 Post(s)
    Injectors 1 and 4 are way off in MY opinion, anything over +/-1 causes problems and for me even number 2 is off. I will only fit Genuine Bosch exchange units (in an untampered with and sealed Bosch box) as at £647.40 each, genuine VAG exchange units are insanely expensive. Unfortunately these can be difficult to obtain and even then are around £500.
  4. Re: Injectors issues? Rough idle + black smoke puff with knock sound on crank engine start
    Jan 2019
    London
    Quote Originally Posted by Ste1981 View Post
    Here's the torsion value: torsion-value.jpg
    Does it need to be closer to 0? Sorry if this is a super dumb question, I'm a total noob.
    oh well, considering that I paid £700 for the car last year, I'm not really sure I will put another £1k in. From what I've seen online so far, the cheapest workaround or temporary fix could be a Diesel Purge, which I plan on doing this weekend. Hopefully, that will do something, in a good way. The previous owner has replaced two of the injectors.
  5. Re: Injectors issues? Rough idle + black smoke puff with knock sound on crank engine start
    Mar 2017
    Nottingham
    9 Post(s)
    Yes supposed to be around the 0 mark although that being said my golf was a bit shakie with a bit of rattle on cold mornings then had the timing belt n water pump done by Vw and when I got it back the torsion was at -2.5 and it feels a lot better
  6. Re: Injectors issues? Rough idle + black smoke puff with knock sound on crank engine start
    1837 Post(s)
    Some people including my friend Greg set them up like like that as they do creep as they age due top belt stretch. Basically I aim for plate and pin perfection after two rotations of the engine and that normally gives a very low value.
  7. Re: Injectors issues? Rough idle + black smoke puff with knock sound on crank engine start
    Jan 2019
    London
    I did a diesel purge today, however, the injectors values stayed pretty much the same, with no significant improvements. Any chance the injector values be affected by some other factors? During the diesel purge I was expecting black smoke and the liquid in the jar to get dirty, but nothing like that happened, everything went smooth.
  8. Re: Injectors issues? Rough idle + black smoke puff with knock sound on crank engine start
    1837 Post(s)
    You need to replace the injectors showing over +/-1 correction values.
  1. Puff of smoke on start up
    By nizzex in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2018, 08:18 PM
  2. Replies: 0
    Last Post: 07-12-2015, 04:17 PM
  3. Please Help A4 B8 2.0 TDi Problems Starting, Rough Idle & Steering Knock
    By jamin128 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-04-2014, 09:34 AM
  4. High revs on start up and a puff of black smoke
    By portovechios in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-08-2012, 10:39 AM
  5. Please Help Lots of black smoke, loss of power and now rough idle when cold
    By badboi331 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-10-2011, 08:40 PM
