Thread: Dab
Results 1 to 10 of 11
  1. Dab
    Sep 2016
    Ipswich, England
    I've always had poor reception with DAB (repeated drop outs)
    Reading forums appears to suggest this can be addressed with a software issue?
    I had a new Q2 courtesy car and the DAB reception was rock solid
    Any one had experience of this issue, how did you address it, if at all?
  2. Re: Dab
    Jan 2013
    Wessex. and Southern France
    66 Post(s)
    Stopped using mine it's so bad.
  3. Re: Dab
    Sep 2009
    Preston
    52 Post(s)
    My DAB has been rock solid in my A7, but I do use FM more than DAB apart from the odd station. I've never heard of a software fix for DAB reception. Do you have a dash cam? I've heard these can interfere. Maybe have a look at the aerial too or may be it's just the reception is poor in your area.
    From Apr 2017 - now: Oct 2016 (66) Audi A7 3.0 TDI quattro (FL - MY17), 272 ps, Black Edition (Tech pack, Parking Pack, Folding Mirrors), Mythos Black.
    Gone - From Oct 2013 - Mar 2017:
    Mar 2013 Audi A6 C7 S-line 2.0TDi Manual, Daytona Grey.
    (Gone) - From Sep 2011 - Oct 2013
    : Sep 2010 Audi A6 C6 S-line Special Ed (Le Mans) 2.0 TDi Manual, Polar Blue./(Gone) - From Sep 2009 - Sep 2011: Sep 2008 Audi A6 C6 S-line 2.0 TDi Auto, Akoya Silver.
  4. Re: Dab
    Apr 2007
    It's made worse if you have anything charging from the 12v sockets because it back feeds . I just dont even bother with it now it's that useless.
    Sent from my SM-G965F using Tapatalk
  5. Re: Dab
    Jul 2016
    Chestfield kent
    45 Post(s)
    DAB reception is very dependent on location and topography. I am in the south east and find it very good, but there are a few areas that I know I will loose it in. This site may help with UK transmitter locations and coverage, it really depends on where you are located. ukdigitalradio: Coverage
  6. Re: Dab
    Jan 2013
    66 Post(s)
    Around west Berks it's pathetic. And when you can get it the nitrate is so low, and half the station's don't even broadcast in stereo. I chuckle when people shell out extra money for Bose and b&o for their cars, then sit and listen to DAB.
  7. Re: Dab
    Jul 2016
    Chestfield kent
    45 Post(s)
    Hi. Discovered something interesting this week regarding DAB reception. The heater rear screen is used as the aerial for radio reception. This week I installed a dashcam in the rear window. On a 120 mile trip round the M25 and back home a couple of days later, I noticed the DAB kept dropping leaving me on FM. Thinking it may be a transition fault at the time did not worry to much, but, today again no DAB. Thinking about it as it had been fine up until last week, I unplugged the cam, DAB back to normal... So conclusion, dashcam can cause interference at DAB frequencies. So if you experience a poor DAB reception and have a dashcam, switch it off it may be causing your DAB problem. Guess then you have to accept that you may have to settle for FM...... Grrrrrrrrrr
  8. Re: Dab
    Aug 2009
    cheshire
    46 Post(s)
    there are some extra wires on the rear screen that the dab uses. Literally 2 lines iirc. dashcams have been an issue with dab reception which blackvue know about. I think a ferrite code wrapped around the dashcam cable helps
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill plates,Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  9. Re: Dab
    Sep 2009
    Preston
    52 Post(s)
    I've not heard of Thinkware rear dashcams causing DAB issues, but have read of the Balckvue's doing so. Mine is a Thinkware F770, along with a rear, and not had any problems with DAB.
  10. Re: Dab
    Feb 2018
    Fife
    8 Post(s)
    As people have said, could be caused by poor RF supression in either a dashcam power supply, the link cable between front and rear cams or any other charger you have.
    I swapped out my 12v chargers in the car for those with better RF suppression and binned the old ones. DAB is far far better now.
