Thread: ABS module coding HELP
  1. ABS module coding HELP
    Sep 2015
    Wraysbury
    Hi guys,
    I tried to replace a EPB module and it didn't work as planned.
    I coded the ABS and code was accepted, coded the EPB module code was accepted but when I go into testing Error everywhere. group 063 error, group 061 error...
    Could someone kindly provide some knowledge about what I'm missing. And also if you don't mind the ABS login Code and the soft code number etc.. to double check that I imputed the right codes.
    Below you have some info about the car.
    vin: WVWZZZ3CZ8E108594
    Address 03: ABS Brakes Labels: 3C0-614-109-0C4.clb
    Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
    Component: J104 C4 440 V2 0003
    Revision: --020--- Serial number: 00000776413416
    Coding: 0001294
    Shop#: WCS 05311 000 00000
    VCID: 1F4A7B53CEAE7BC644-804A
  2. Re: ABS module coding HELP
    Oct 2017
    Halifax, West Yorkshire
    22 Post(s)
    When replacing epb, you have to follow a series of tests before all fault codes are clear. Also use a battery charger when testing EPB through VCDS and earlier modules didn't like users exiting the parking brake module on VCDS immediately, rather wait a few seconds. Follow this guide and it's associated pages:
    VW Passat (3C) Brake Electronics - Ross-Tech Wiki
    Have you done all the above in the link?
  3. Re: ABS module coding HELP
    Oct 2019
    York
    Passat b5.5 2004- VIN is WVWZZZ3BZ5E114537
    It was an abs module put in, that needs coded in
    Steering angle sensor also needs coded as a result of new abs module, error code is g85 not matched
    Can anyone help?
    Need codes???
    Thank you in advance
  1. Whats your ECU / Module 01 coding II...
    By gupsterg in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-12-2020, 05:59 AM
  2. Module Re-coding
    By PuddyTat in forum Scotland
    Last Post: 19-02-2018, 02:48 PM
  3. ABS Module Will Not Hold Its Coding
    By dakes2 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-09-2016, 08:02 PM
  4. A4 B7 bluetooth module coding
    By UVB in forum VCDS - General Questions
    Last Post: 21-06-2014, 02:29 PM
  5. A4 CCU module coding goes to: 000000
    By novadan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-06-2009, 04:04 PM
