Thread: Turbo Actuator fault - J724
  1. Turbo Actuator fault - J724
    Aug 2007
    HI,
    Has anyone replaced the electronic actuator for the turbo on the 3.0tdi engine ?
    VCDS is showing this has failed but I need to calibrate the new actuator before fitting and I'm struggling to find anyone that can do it - apart from a main dealer
    Would be grateful for any help or if anyone knows a company that will calibrate it for me
  2. Re: Turbo Actuator fault - J724
    Aug 2010
    maidstone
    25 Post(s)
    I have a turbo actuator fault (intermitant) and my local garage (friends) have told me they can now program any new actuator, where as before it was only Audi. They are Audi specialists, but may be too far fro you.
    Maidstone, Kent, Kent Automotive - Audi & Volkswagen Servicing Specialist In Maidstone Kent
    I have been using them for years, from Audi and Volvo to the current Audi, and they are very good and much cheaper than Audi of course. If you call them, just say Craig suggested them
  3. Re: Turbo Actuator fault - J724
    Aug 2007
    Many thanks for the recommendation, I am sorted now but it will be a handy contact for the future.
    I ended up having to replace the turbo as it had a broken wastegate - bit of a pain as I'd got the actuator programmed and now its sat in my garage !!
  1. Please Help P0046 turbo actuator fault
    By WarrenA6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-06-2022, 06:06 PM
  2. Replies: 6
    Last Post: 16-11-2015, 05:36 PM
  3. Passat 2008 turbo actuator fault
    By jasonmking in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-09-2014, 07:09 PM
  4. Heater fault - Actuator motor fan temperature flap fault
    By jackdaw1990 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-12-2013, 02:30 PM
  5. Please Help Turbo controller (J724) wanted
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-06-2012, 08:03 AM
