Thread: B7 3.0 TDI Turbo removal help!
Results 1 to 10 of 10
  1. B7 3.0 TDI Turbo removal help!
    Jan 2014
    Woking, Surrey
    Hi all
    Does anyone know how to release the lower oil return pipe to free the turbo assembly please?
    It's loose, but cant seem to figure out the lat bit!
  2. Re: B7 3.0 TDI Turbo removal help!
    1840 Post(s)
    They are always tight and take some force to lift up, often two people in the engine bay lifting up.
  3. Re: B7 3.0 TDI Turbo removal help!
    Jan 2014
    Woking, Surrey
    Cool, thanks. We got it out yesterday... Going to be tricky getting it back in? I assume its a new O ring and firm push... there is a 10mm bolt near the top of the pipe which I guess keeps it in place but doesn't necessarily pull the pipe into the turbo
  4. Re: B7 3.0 TDI Turbo removal help!
    1840 Post(s)
    New O ring and some lubricant. We use a silicone grease that comes in Powerflex bush kits but you don’t want any in the oil, if you were in a corner then a light wipe of the O ring and the top of the opening with washing up liquid should not hurt but it does contain salt.
  5. Re: B7 3.0 TDI Turbo removal help!
    Jan 2014
    Woking, Surrey
    Lovely, thanks. It went in ok in the end - with a nice positive ' snick' !
    Sadly i still have a limp mode issue, see other thread :-(
  6. Re: B7 3.0 TDI Turbo removal help!
    Feb 2010
    Derbyshire
    I'm just about to remove the turbo on mine due to a failed actuator.
    So it the lower oil return pipe push fit?
    So hopefully no need to access from the wheel arch and remove a totally inaccessible bolt? Hope so!
    Thanks.
    2003 Audi 1.9tdi 130
    1999 BMW 318i
    1988 Porsche 911 Carrera
  7. Re: B7 3.0 TDI Turbo removal help!
    1840 Post(s)
    Which car and engine?
  8. Re: B7 3.0 TDI Turbo removal help!
    Feb 2010
    Derbyshire
    Sorry, 2005 A6 3.0tdi Quattro.
  9. Re: B7 3.0 TDI Turbo removal help!
    1840 Post(s)
    Yes it is pushed in but can take some force to lift up, often you end up climbing in the bay to get the angle without pulling your back.
  10. Re: B7 3.0 TDI Turbo removal help!
    Feb 2010
    Derbyshire
    Thanks Crasher that's what I wanted to hear, I'll be better at wrestling from above than contorting from below unnecessarily.
  1. Turbo removal
    By andyjerv in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-05-2013, 11:02 PM
  2. Turbo removal!!
    By Donnelly in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-07-2010, 12:51 AM
  3. Turbo removal
    By GRAHAM.C in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-11-2009, 11:06 PM
  4. Turbo Removal - How?!
    By thorpyuk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-03-2009, 11:56 AM
  5. A6 2.5 Tdi Turbo removal
    By elt in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 19-12-2008, 08:54 PM
