Thread: Touran 1.9tdi bxe misfire issue
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Touran 1.9tdi bxe misfire issue
    1837 Post(s)
    It has probaly had a new clutch as the easy way is to remove the slave rather than disconnect it as getting the system working again can be a real pain, as you are finding. We use a pressure bleeder as it makes it much easier, if actually possible really but try pumping the pedal by hand and holding it down and then have a minion release the bleed nipple, then tighten, the pull the pedal up and after around 30 attempts you may start to get a pedal, no it should not leak, have you lost the tiny rubber seal off the end of the pipe? The repair kit is £14.22, part number 1K0 798 741
  2. Re: Touran 1.9tdi bxe misfire issue
    Mar 2019
    Thanks Crusher
    ive definitely lost that bigger part. Where's the quickest place to get one of these kits?
    Im awaiting a call back from TPS.
  3. Re: Touran 1.9tdi bxe misfire issue
    1837 Post(s)
    Yes, TPS.
  4. Re: Touran 1.9tdi bxe misfire issue
    Mar 2019
    Misfiring Touran update.
    Sorry for the long delay. I've still got the touran, I haven't given up!
    Had it looked at by another local mechanic who couldn't read any live coms from the car. He passed me over to a reputable auto-engineer. A bit unreliable but determined that it wasn't a faulty injector nor a faulty loom. Then work got too busy so I've used it v.gently. I think the misfire is getting worse. A different source had me blank off the egr valve. That did nothing to help and in fact, made it run worse.
    Next stop- looking at a worn camshaft. Please advise on what sorts of parts would be required?? Think I've seen a list on a different thread.
  1. touran misfire? issue
    By colbal in forum Touran - Sharan - Caravelle
    Last Post: 24-01-2016, 11:59 AM
  2. T5 1.9tdi misfire
    By leeT5 in forum The Commercial Range
    Last Post: 14-02-2010, 11:29 PM
  3. MIsfire on my A3 1.9Tdi 02
    By Lapchien in forum Audi A3 - Archive Topics
    Last Post: 20-07-2008, 02:34 PM
  4. 04 1.9TDI Touran issue
    By kennyruss in forum Touran - Sharan - Caravelle
    Last Post: 07-05-2008, 03:33 PM
  5. Replies: 13
    Last Post: 01-04-2008, 02:24 PM
