Thread: Airbag Light has come on
  1. Question Airbag Light has come on
    Jan 2009
    Hello All,
    I have a 2006 Golf GTI.
    I am looking to see if anyone would know why (anyone had this happen before) or possibly have some solutions for the Airbag warning light that has randomly just come on whilst i was driving on the weekend. I have got a friend to scan my car using VCDS where the below fault code is displayed, I have tried to clear it but it just comes straight back on.
    01588 - Igniter for Head-Airbag; Drivers Side (N251)
    001 - Upper Limit Exceeded - MIL ON
    Any help on resolving this issue would be greatly appreciated and if anyone knows someone near the Newcastle Upon Tyne area who can fix please let me know.
    Many Thanks in Advance
    Shahid
  2. Re: Airbag Light has come on
    May 2017
    Wrexham, N.Wales
    Hi Shahid, it's possibly a poor connection either on the airbag connector that runs through the top of the D pillar trim or there's another if you follow this wire nearer the bottom of the D pillar. You'll need to remove the header trim to have a proper look.
    Sent from my H8216 using Tapatalk
  3. Re: Airbag Light has come on
    Jan 2009
    Hi Stuart, Thanks for responding. I guess the D pillar is the one on the driver side next to windscreen. Is there only the airgbag wire in there or will there be others?
  4. Re: Airbag Light has come on
    May 2017
    Wrexham, N.Wales
    Hi mate, there will be a bundle of wires in there, if I remember rightly the air bag connector should be yellow. It was in my 2006 GT and both car should be the same.
  5. Re: Airbag Light has come on
    Jan 2009
    Thanks Stuart, I will give this a try on the weekend, hoping its a loose wire which i can just push back into the connector.
  1. Airbag light on.....airbag sensor location G180?
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-12-2016, 04:56 PM
  2. Disconnected passenger airbag key switch, now airbag light is on
    By garmcqui in forum Golf MK7 - 2013 - 2019
    Last Post: 13-03-2016, 06:38 PM
  3. Oh the Airbag Light... 01217 Side Airbag Igniter Driver Side (N199)
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-02-2015, 02:47 PM
  4. golf mk4 tdi airbag light and abs light
    By swally34 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 14-06-2013, 09:12 PM
  5. Please Help Engine Light & Airbag Light stay on
    By sobberz in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-06-2010, 07:27 AM
