Thread: low oil pressure STOP, oil pump?
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 55
  1. Re: low oil pressure STOP, oil pump?
    #41
    Sep 2019
    Ascot
    Have you done of these Gaz? Or do you know anyone that offers the service.
  2. Re: low oil pressure STOP, oil pump?
    #42
    Sep 2019
    Ascot
    If you fancy earning a few bob on the side you can do mine if you want ?
  3. Re: low oil pressure STOP, oil pump?
    #43
    Aug 2019
    Telford Shropshire
    9 Post(s)
    All done ppl fitted everything in today took it for an hours drive everything sounds as it should be u never know after replacing the shaft and everything else fingers crossed that dreaded oil pressure light stays off thanks to all for the help and sound advice ��
  4. Re: low oil pressure STOP, oil pump?
    #44
    Apr 2016
    London/UK
    23 Post(s)
    Quote Originally Posted by Nabz1310 View Post
    3 years later, can you give us an update on how it worked pls?
    I think I have to do mine now and doing a lot of research on it
  5. Re: low oil pressure STOP, oil pump?
    #45
    Aug 2019
    Telford Shropshire
    9 Post(s)
    Quote Originally Posted by johnro79 View Post
    Hi mate... all good news to report back 👍 no issues whatsoever... and damn it's been 3 years already lol 😆
  6. Re: low oil pressure STOP, oil pump?
    #46
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Been over 6 years for me with a KMB replacement.
    Mad Mitch
  7. Re: low oil pressure STOP, oil pump?
    #47
    Apr 2016
    London/UK
    23 Post(s)
    I believe (and hope) ill only need New Oil Pump - 03L 115 105 D
    WAUZZZ4G6EN078816 270k miles
    Does it come with a 100 hex key too or that's only with the kits?
    Balance shaft timing tool. If I'll just replace the pump, do I need this tool?
    I also have my engine shaking at idle ...
  8. Re: low oil pressure STOP, oil pump?
    #48
    1840 Post(s)
    Your car has the 100mm key, 03G 115 281 E. The pump is now 03L 115 105 F £276.77, I would use a Febi 34723
  9. Re: low oil pressure STOP, oil pump?
    #49
    Apr 2016
    London/UK
    23 Post(s)
    Quote Originally Posted by DMitch16 View Post
    i went and got a KMB pump and kit 10 for my car
    i have oil +filter + sealant (V-Tech Vital Copper RTV Gasket Makers-85gm)
    unless anything else is bad ore just can't be reused, what else do i need to have handy?
    monday or tuesday gonna take the sump off and see what's in there
  10. Re: low oil pressure STOP, oil pump?
    #50
    Jan 2012
    10 Post(s)
    87 Post(s)
    If you do end up replacing the balance shaft you will need the 8 balance shaft mounting bolts which are single use only (TTY)
    As the balancer unit is seriously heavy I would not skimp and reuse the mounting bolts for the sake of 40 odd quid and would use new bolts. The ones holding the 2 halves of the balance unit are imo ok to reuse as the exact replacements and also the special shells / bushings inside the unit cannot be sourced from well, anywhere I know of in the UK. I do see refurbished balancer units with new shells online but have no idea where to source the new shells which have a cut out to match to the oil channels and are fairly small. I have seen a Polish video of a workshop refurbishing these balancer units and if anyone knows where to get the specific shells / bushings I would be eternally grateful, as I would like to renew mine whilst I am changing my main and rod bearings. I might just get a refurb u it for £350 but would prefer not to spend that much.
    Mad Mitch
  1. Please Help STOP. Low oil pressure
    By TaximanWsM in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-09-2013, 12:39 PM
  2. Oil Pressure Stop Help please
    By parkerm35 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-02-2013, 03:14 AM
  3. STOP oil pressure warning - oil pump failure! Help please
    By jamer78 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 03:54 PM
  4. Stop!!! Low Oil Pressure!!!!!
    By bubblesaint in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-03-2011, 04:43 PM
  5. Please Help STOP: Oil pressure
    By blackpassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2009, 08:53 PM
