Thread: Passat B6 Injector Replacement
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
  1. Re: Passat B6 Injector Replacement
    #21
    Mar 2019
    Seaham
    That is THE sure way to prove an injector is faulty, what is the part number on the body?
    From what I can see the numbers on the injector are 142011 070612 and then below is 03G130 073D
  2. Re: Passat B6 Injector Replacement
    #22
    1840 Post(s)
    Someone in the cars past life screwed up and didn't take it in for the 23H9 Campaign which has now expired.
  3. Re: Passat B6 Injector Replacement
    #23
    Mar 2019
    Seaham
    Thanks Crasher, just my luck! Do I replace like for like now with the one dodgy injector?
  4. Re: Passat B6 Injector Replacement
    #24
    Mar 2019
    Seaham
    Quote Originally Posted by DieselMonster View Post
    If you can check it then check it. Do the small tests first before jumping on replacing the injector.
    Tried to PM you but your inbox is full so wont go through
  5. Re: Passat B6 Injector Replacement
    #25
    Mar 2019
    Seaham
    Just thought I’d post an update. After disconnecting injector 1 and the engine starting up, I ordered a recon injector and a new wiring loom which was damaged on removal due to brittle connections.
    During the week I backed off the rocker arm on injector 1, removed rocker shaft and removed number 1 injector.
    To remove the injector I used a heel bar, a rag under the heel and levered the injector our, no excessive force needed.
    New injector fitted today and built back up, injector set as per manual and now running sweet as a nut. Just waiting for VCDS to code in the new injector, (I take it that’s what I need to do) even though she’s running ok. Thanks everyone who offered advice and guidance
  6. Re: Passat B6 Injector Replacement
    #26
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    It is a PD so no matching needed like the Common Rail engines. This job is done. Great result it seems.
    Mad Mitch
  7. Re: Passat B6 Injector Replacement
    #27
    Mar 2019
    Seaham
    Quote Originally Posted by DMitch16 View Post
    Ah brilliant, even better!!!
  8. Re: Passat B6 Injector Replacement
    #28
    Mar 2019
    Seaham
    Hi Again,
    The car is still running but when running at around 60-70mph at 2000rpm when I put my foot down it feels as though the engine is misfiring. She'll cruise along at whatever speed, quite happily, just the initial power needed to get there that gives the feel of a misfire. Number 1 injector has been replaced along with a new injector harness.
    We set Injector 1 on fitting, then today I've reset the heights of all 4 injectors but still getting the same problem.
    Any ideas?
  9. Re: Passat B6 Injector Replacement
    #29
    1840 Post(s)
    study the live data to see which other injector is not correct, it will be 25% easier now as it is 1, 2 or 3.......
  10. Re: Passat B6 Injector Replacement
    #30
    Mar 2019
    Seaham
    Does that mean another £200 for another injector?
  1. Question A4 b6 1.9 tdi injector loom replacement
    By brucielee in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-05-2017, 09:48 AM
  2. Question Injector replacement
    By joedredd in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-08-2016, 01:08 PM
  3. Please Help Injector replacement
    By Y90USF in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-07-2011, 12:50 PM
  4. Please Help Fuel Injector Replacement
    By Sigmond in forum Golf MK3 - 1993 - 1999
    Last Post: 14-01-2010, 09:31 PM
  5. Injector replacement.....
    By djl78 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-03-2009, 10:35 PM
