Thread: Air Suspension Error: one off: what thoughts
Results 1 to 8 of 8
  1. Air Suspension Error: one off: what thoughts
    Dec 2009
    Dublin, Ireland
    25 Post(s)
    Hi all
    had an Air Suspension error yesterday, but it was gone when I used the Q7 later in the day.
    No driving symptoms, and the Q7 has an easy life:
    See VCDS scan below: What thoughts?
    Address 74: Chassis Control (J775) Labels:* None
    Part No SW: 4M0 907 777 E HW: 4M0 907 777 E
    Component: Fahrwerk-SG H10 0104
    Air Suspension Compressor:
    Subsystem 1 - Part No SW: 4M0 907 589 B HW: 4M0 907 589 B
    Component: V66LFKompOLV H06 0012
    Serial number: 00000000004130056635
    Coding: 303030
    1 Fault Found:
    3178507 - Compressor for Suspension Level Control
    C118D 07 [008] - Mechanical Failure
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 52
    Mileage: 42084 km
    Date: 2019.03.13
    Time: 10:55:41
  2. Re: Air Suspension Error: one off: what thoughts
    Mar 2016
    KEnt
    22 Post(s)
    Did the error appear on the dashboard? Also did you notice a difference while driving the car.
    Never had that error pop up before to be honest
    Sent from my SM-G965F using Tapatalk
  3. Re: Air Suspension Error: one off: what thoughts
    Dec 2009
    Dublin, Ireland
    25 Post(s)
    Quote Originally Posted by Papereyes View Post
    No symptoms. Message appeared on drivers digital display.
    Audi said leave it see if anything develops. Might be nothing. Have warranty until July...
  4. Re: Air Suspension Error: one off: what thoughts
    Jul 2016
    Munich
    I would have it checked out. I had the same kind of behaviour when I just got the car...turned out to be a faulty air suspension chipset.
    Cheers,
    Sven
  5. Re: Air Suspension Error: one off: what thoughts
    Apr 2016
    Stansted
    169 Post(s)
    Is it possible the battery charge was low? That’s the only time I’ve seen strange warnings that never reappeared.
    Former Q7 owner
  6. Re: Air Suspension Error: one off: what thoughts
    Sep 2017
    Bristol
    11 Post(s)
    Hmmm interesting. I had a similar issue. Turned out the pipes coming out of the compressor under the car at the rear passenger side had chafed.
    Symptoms were the car would be fine then about 20 mins later the alert would come up on the dash. Turned the car of and back on again it was fine. This happens for a couple of days then had a complete failure. Had to call Audi assist out. Car got towed back to the dealers. This happened after the car was a year old. There was apparently a repair kit for it. It was covered under warranty and fixed within a couple of days
    If I can I will post some photos.
  7. Re: Air Suspension Error: one off: what thoughts
    Sep 2017
    Bristol
    11 Post(s)
    iCloud Car looking sorry for itself.
    iCloud - Error on dash
    iCloud - chafed pipes
  8. Re: Air Suspension Error: one off: what thoughts
    Dec 2009
    Dublin, Ireland
    25 Post(s)
    Quote Originally Posted by Milesunder View Post
    Thanks for posting the photos. Where were the Chafed pipes. I don't think I have that problem, as the car remains level when unattended, but it would be good to know. I did 250,000Km in a VW phaeton with broadly similar Air Suspension and never had a problem, so hopefully this was just a gremlin.
    However I will have it checked out before the warranty ends.
  1. Self Levelling Suspension Fault - Locked Suspension Yelow Warning on Dash
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2014, 05:01 PM
  2. Replies: 0
    Last Post: 09-09-2012, 10:42 PM
  3. Replies: 0
    Last Post: 09-07-2009, 03:35 PM
  4. Replies: 0
    Last Post: 09-07-2009, 03:03 PM
  5. S3 Haldex error 65535 internal control module memory error?
    By merlin2002 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-06-2009, 09:08 AM
