The Avant has done plenty of miles, the rear tyres have both stripped off the inner edges indicating toe out or negative camber, both tyres equally wrecked.
Any ideas as to common issues to rear suspension that cause this on the C6 to help me investigate.
I have not had it 4 wheel aligned yet, I believe the toe and camber can be adjusted but see no reason the rear would have gone so far out. I need to check bolts are not rusted up to adjust beforehand anyway..it is old and likely solid!! Guidance as to what adjusts would be useful.
