Thread: Replacing Oil Filter Housing - any tips!
  1. Replacing Oil Filter Housing - any tips!
    Dec 2015
    Scotland
    11 Post(s)
    Hi folks, my oil filter housing is leaking at the block so I am going to replace it.
    It looks pretty tight in there and there are very few decent videos how to on you tube.
    Any tips on getting it out, I'm hoping I can work mainly from above and removing the anti shudder valve plus other hoses gain enough room!
    Any thoughts appreciated or replacement guides!
    Audi A6 2008 Saloon Sline 2.0 Tdi BRE
    Vw Passat B7 1.6 tdi 2012 estate
    Previously - 2008 1.6 tdi Mini, 2006 Mazda Mx5 1.8, 2002 Vw Golf 1.9 tdi SE, 2010 Bmw 318d Msport, 1992 Porsche 944 2.5 turbo, 1986 Porsche 944 2.5 NA, 1984 Porsche 944 2.5 NA
  2. Re: Replacing Oil Filter Housing - any tips!
    Dec 2015
    Scotland
    11 Post(s)
    Just as a follow up to this...............
    I managed to do this job completely from above as I was limited by lack of ramp, I don't think it would have been much easier attacking it from below but may have helped a little.
    The biggest part of this job is removing several (maybe 6-8) coolant hose connections to create space to do the work, this was made easier by using a good spring clip removal tool on a cable for awkward access.
    I used a siphon to remove about 1 litre of oil (I found that I got very little leaking when I removed the housing) via the dipstick, then used the siphon to drain the filter housing of oil by removing the oil filter first. I drained all the coolant.
    I sourced a Metzger oil filter housing from GSF car parts for £83 inc vat, it appears to be a VW part or at least of reasonable quality. I was also quite surprised that it came with a new oil cooler, oil filter and all seals & gaskets, there are some very cheap ones on ebay for £40 which I wouldn't rate and TPS wanted over £200 for one, VW was £300.
    There seems to be a bit of a manufacturing defect with these housings because the galley / waterway for the collant seems to break where it meets the block and a fair few people in varying VWs complain of this with the usual symptom being coolant loss.
    Anyway I've done 500 miles and so far all looks good. I'll try and post some pics.
  3. Re: Replacing Oil Filter Housing - any tips!
    1840 Post(s)
    I was going to say remember the bracket to block bolts are one time only, tighten following the correct diagonal sequence in two stages to 14Nm + 180 degrees and whilst in there, change the crank sensor so you don't have to take it apart again later...
  4. Re: Replacing Oil Filter Housing - any tips!
    Dec 2015
    Scotland
    11 Post(s)
    Ah oh well reused the originals.......
    At least it will be quicker 2nd time around!!
  1. Oil Filter Housing Cap removal
    By A6forever in forum A8 - S8 - V8
    Last Post: 01-09-2015, 07:28 PM
  2. Question How do I get the oil filter out of the housing on a VW Fox 1.2
    By kevinbailey in forum Polo - Derby - Lupo - Fox
    Last Post: 12-05-2013, 01:34 PM
  3. Question Mk3 GTI 16v (ABF) oil Filter Housing Leak
    By richardm in forum Golf MK3 - 1993 - 1999
    Last Post: 28-08-2012, 10:18 AM
  4. tdi 140 oil filter housing
    By karlcb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-10-2009, 05:29 PM
  5. Oil in air filter housing
    By rjamey_uk in forum Bora - 1998 - 2005
    Last Post: 29-09-2009, 11:52 AM
