Thread: Another B6 1.9tdci temp gauge issue
  1. Another B6 1.9tdci temp gauge issue
    Jan 2010
    peterborough
    Picked up a moon miler that I just need to run for a few months while between company cars and the temp gauge mainly stays at minimum; I have seen it wander a bit up to 70 and down again. I’m happy to try a new sensor in it but I’m wondering how ‘safe’ I am driving it in the meantime. There’s good heat from the matrix. If the engine started to overheat would I get a dash warning before all hell broke loose?
    Car was plugged in briefly to read errors (not sure what system it was plugged into tho) and it didn’t show an error for the temp sensor.
    It DID show an error on glow plugs 2&3 and an ABS sensor error but there’s nothing on the dash and the little ‘check’ button does it’s thing without any warnings
    Any advice? Anything to worry about?
  2. Re: Another B6 1.9tdci temp gauge issue
    Jan 2009
    Birmingham
    35 Post(s)
    replace the coolant temp sensor use a genuine part running the car as it is will just give you poor mpg
  3. Re: Another B6 1.9tdci temp gauge issue
    Dec 2010
    Weston Super Mare England
    Hi , don’t know if you’ve solved your problem but I had a similar thing on mine. Got my garage to change thermostat and now reaches 90 & stays there.
    Andy
  4. Re: Another B6 1.9tdci temp gauge issue
    May 2012
    Everywhere
    308 Post(s)
    Always do new CTS , thermostat and thermostat housing .
  5. Re: Another B6 1.9tdci temp gauge issue
    1837 Post(s)
    Generally, ignore the accuracy of the dash temp gauge, it is laughable.
  6. Re: Another B6 1.9tdci temp gauge issue
    May 2012
    Everywhere
    308 Post(s)
    Iirc , somewhere 70-120°C ?
    And you don't have to have genuine parts .
    Meyle CTS ,
    Whaler thermostat .
  7. Re: Another B6 1.9tdci temp gauge issue
    1837 Post(s)
    I have seen them show 90 when the measuring block says 77 and still say 90 when the measuring block says 117!
  1. Please Help Temp gauge still cold after temp sensor replacement
    By cka4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-04-2018, 11:26 PM
  2. Oil temp gauge issue's
    By boomd in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-03-2015, 12:16 AM
  3. Coolant temp gauge and oil temp gauge - FIXED - 1.8 TQS
    By leighmagill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-03-2015, 05:17 PM
  4. Advice required by newbie MK4 owner - Blowers/Temp gauge issue...
    By SamwelGTTDI in forum Golf MK4 - 1999 - 2004
    Last Post: 04-12-2010, 07:15 PM
  5. temp gauge and fuel compsumption gauge
    By mikeA4_88 in forum Archive posts
    Last Post: 03-02-2008, 11:23 PM
