Thread: air suspension
Results 1 to 10 of 17
  1. air suspension
    May 2008
    my air compressor runs for about three minutes after i start and drive my q7.
    the previous owner told me he replaced the compressor!
    and it makes some noise!
    i think this is not right?
    am i wrong?
  2. Re: air suspension
    1840 Post(s)
    Does it sink when left?
  3. Re: air suspension
    May 2008
    hi crasher, not that ive noticed.
  4. Re: air suspension
    1840 Post(s)
    Odd then, if it is not leaking then it begs the question why it is pumping so hard, possibly a reserve system weep. Some measuring block time by someone who knows the system would be informative.
  5. Re: air suspension
    May 2008
    thanks crasher,
    your words are over my head!!
  6. Re: air suspension
    1840 Post(s)
    It would be worth getting a VAG specific fault code scan carried out, ask for a print out of the results.
  7. Re: air suspension
    May 2008
    thanks crasher,
    ive bought a laptop with vcds and ross tech cable from ebay(used unlimited vins)
    ill have to learn how to use it!!
    and have reg on ross techs forums.
    so will be looking for HELP!!!
    https://www.ebay.co.uk/itm/VAGelsawi...53.m2763.l2649
  8. Thumbs up Re: air suspension
    May 2008
    hi crasher, i know its A bit late!
    i got this from vcds in may..
    Address 34: Level Control Labels: 4L0-910-553.lbl
    Part No SW: 4L0 910 553 B HW: 4L0 907 553
    Component: LUFTFDR.-CDC H03 7550
    Revision: --H03001 Serial number: 15.1528-0095.2
    Coding: 0015510
    Shop #: WSC 31414 790 00001
    VCID: 295922E0801E5202AA-807C
    2 Faults Found:
    01577 - Turn-Off due to Over-Temp
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 172
    Mileage: 221100 km
    Time Indication: 0
    Date: 2019.05.01
    Time: 16:20:11
    Freeze Frame:
    Error Code: 68
    01772 - Signal from Level Control Pressure Sensor (G291)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 173
    Mileage: 221106 km
    Time Indication: 0
    Date: 2019.05.01
    Time: 18:40:54
    Freeze Frame:
    Error Code: 78
    i cant upload the complete scan results?
    hope this makes sense!
  9. Re: air suspension
    1840 Post(s)
    In advanced reply settings, use the hashtag button near the end of the second row of tools and paste your reply in between the boxed code code tags
  10. Re: air suspension
    May 2008
    thanks for your reply.
    got it!
  1. Please Help Front suspension spring and suspension arms
    By Stavros_Davros in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-06-2018, 02:16 PM
  2. Audi A6 c7 2013 allroad suspension problems (or any c7 with air suspension)
    By Audrius in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-01-2015, 10:53 PM
  3. Self Levelling Suspension Fault - Locked Suspension Yelow Warning on Dash
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2014, 05:01 PM
  4. S Line suspension vs Sports Suspension - Retro fit
    By scoobmw in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-10-2010, 09:23 AM
  5. Mechanical differences between Sport suspension and ordinary suspension
    By Novica in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-06-2010, 05:03 PM
