Thread: air suspension
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: air suspension
    May 2008
    Code:
    Wednesday,01,May,2019,19:24:08:59248VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 18.9.1.0
    Data version: 20190114 DS296.0
    www.Ross-Tech.com
    VIN: WAUZZZ4L57D068218   License Plate: Y501GDU
    Mileage: 221110km-137391mi   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 37 42 46 47 4F 52
              56 61 62 67 6C 6D 6F 72 76 77
    VIN: WAUZZZ4L57D068218   Mileage: 221110km-137391miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    34-Level Control -- Status: Malfunction 0010
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    67-Voice Control -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    6F-Centr. Conv. II -- Status: OK 0000
    76-Park Assist -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine        Labels: 059-907-401-ASB.clb
       Part No SW: 4L0 910 401 M    HW: 4L0 907 401
       Component: 3.0L V6TDI  G000AG  0030
       Revision: --H03---    Serial number:
       Coding: 0011775
       Shop #: WSC 31414 790 00001
       VCID: 2C57DBF48FEC472A51-8078
    1 Fault Found:
    001025 - EGR System
                   P0401 - 002 - Insufficient Flow
                 Freeze Frame:
                        Fault Status: 01110010
                        Fault Priority: 0
                        Fault Frequency: 2
                        Reset counter: 255
                        Mileage: 221099 km
                        Time Indication: 0
                        Date: 2019.05.01
                        Time: 16:20:03
                 Freeze Frame:
                        RPM: 1428 /min
                        Torque: 144.3 Nm
                        Speed: 68.3 km/h
                        Duty Cycle: 57.8 %
                        Duty Cycle: 20.9 %
                        (no units): 0.0
                        Duty Cycle: 15.4 %
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans        Labels: 09D-927-750.clb
       Part No SW: 09D 927 750 FS    HW: 09D 927 750 FS
       Component: AL 750 6A           1000
       Revision: 00H64000    Serial number:
       Coding: 0000504
       VCID: 0407535447FC6F6AF9-8050
    No fault code found.
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
       Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
       Component: ESP ALLRAD MK25E1   0130
       Revision: 00H22001
       Coding: 0038033
       VCID: 285F27E49B146B0AB5-807C
    Address 05: Acc/Start Auth.        Labels:. 4F0-910-852.clb
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601100586622
       Coding: 0000147
       VCID: 63C570C8A2B2C852A0-8036
       Subsystem 1 - Part No: 4F0 910 131 E
       Component: FBSAUDIC6 EZS   H45 0080
       Subsystem 2 - Part No: 4F0 910 220 D
       Component: FBSAUDIC6 IDG   H01 0040
    Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
       Part No SW: 4L1 910 732 H    HW: 4E0 035 729 A
       Component: Interfacebox    H43 5570
       Revision: 00000000    Serial number: 387KZ067531471
       Coding: 0000000
       Shop #: WSC 00000 000 00000
       VCID: 2F6DCCF8BEFA3C3274-807A
       Subsystem 1 - Part No: 4F0 910 609 E
       Component: Bedienteil MMIC6H01 0060
       Subsystem 2 - Serial number: 00000001418939
       Subsystem 3 - Serial number: 0114.10.090000000100010899’
       Subsystem 4 - Serial number: 010899’
    2 Faults Found:
    02257 - Remote Control Receiver
                014 - Defective
                 Freeze Frame:
                        Fault Status: 01101110
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 132
                        Mileage: 221098 km
                        Time Indication: 0
                        Date: 2019.05.01
                        Time: 16:11:27
    01042 - Control Module; Not Coded
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 255
                        Time Indication: 15
    Address 08: Auto HVAC        Labels: None
       Part No SW: 4L0 910 043     HW: 4L0 820 043 E
       Component: KLIMABETAETIGUNGH05 0060
       Revision: 00---012    Serial number: 00000000086434
       Coding: 0001046
       VCID: 61C97AC0B8AEDA42B2-8034
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
                002 - Lower Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 173
                        Mileage: 221101 km
                        Time Indication: 0
                        Date: 2019.05.01
                        Time: 16:22:30
                 Freeze Frame:
                        Temperature: 84.0°C
                        Temperature: 29.0°C
                        Load: 0.0 %
                        Temperature: 45.0°C
                        RPM: 760 /min
                        Absolute Pres.: 1.0 bar
                        Current: 0.000 A
                        Temperature: 24.0°C
    Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Component: ILM Fahrer      H17 0240
       Revision: 00000000    Serial number: 4F0907279
       Coding: 0011101
       VCID: 3169CA80A8CE2AC262-8064
       Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H08 0080
       Coding: 00064792
       Shop #: WSC 31414
       Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0090
       Coding: 00150059
       Shop #: WSC 31414
    Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
       Part No SW: 4L0 910 110 B    HW: 4L0 035 110
       Component: MP3-Changer     H43 0390
       Revision: 00043000    Serial number: AUZ5ZBF1019052
       VCID: 1E33013CC950A5BACF-804A
    2 Faults Found:
    02084 - Component Protection
                005 - No or Incorrect Basic Setting / Adaptation
                 Freeze Frame:
                        Fault Status: 01100101
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 0
                        Time Indication: 0
    02095 - Component Protection Active
                000 -  -
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 132
                        Mileage: 221098 km
                        Time Indication: 0
                        Date: 2019.05.01
                        Time: 16:10:58
    Address 15: Airbags        Labels: 4L0-910-655.lbl
       Part No SW: 4L0 910 655 B    HW: 4L0 959 655
       Component: 31 AIRBAG AUDI8RH38 0120
       Revision: 05H38000    Serial number: 0037GD0724FO
       Coding: 0013105
       Subsystem 1 - Serial number: 6332QSME193725259
       Subsystem 2 - Serial number: 6342QSME1927184BJ
       Subsystem 3 - Serial number: 6352QSME1A433E6BT
       Subsystem 4 - Serial number: 6362QSME1A463A63L
       Subsystem 5 - Serial number: 63734SME183A4F1BB
       Subsystem 6 - Serial number: 63834SME183B134B1
    Address 16: Steering wheel        Labels: 4F0-910-549.lbl
       Part No SW: 4F0 910 549     HW: 4F0 953 549 A
       Component: Lenksäulenmodul H08 0230
       Revision: 00H08000    Serial number: 90026063290087
       Coding: 0102142
       VCID: 66C369DC5180BD7A47-8032
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: Lenkradmodul    H07 0090
    Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4L0 920 980 G
       Component: KOMBIINSTR. M73 H17 0120
       Revision: 00700000    Serial number: 5HJ50EWC6
       Coding: 2593448
       Shop #: WSC 19711 067 57207
       VCID: 234530C8E2328852E0-8076
    Address 18: Aux. Heat        Labels: None
       Part No SW: 4L0 910 105     HW: 4L0 815 071 D
       Component: Heizgeraet      H08 0060
       Revision: 0000000A    Serial number: 00000009014264
       Coding: 0000002
       VCID: 60CF7FC4B3A4D34ABD-8034
    Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
       Part No SW: 4L0 910 468     HW: 4L0 907 468
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0900B06B1581DB
       Coding: F55BFE5F307202
       Shop #: WSC 00899 210 92898
       VCID: 6CD71BF44F6C872A11-8038
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 B    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7550
       Revision: --H03001    Serial number: 15.1528-0095.2
       Coding: 0015510
       VCID: 295922E0801E5202AA-807C
    2 Faults Found:
    01577 - Turn-Off due to Over-Temp
                001 - Upper Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 172
                        Mileage: 221100 km
                        Time Indication: 0
                        Date: 2019.05.01
                        Time: 16:20:11
                 Freeze Frame:
                        Error Code: 68
    01772 - Signal from Level Control Pressure Sensor (G291)
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 173
                        Mileage: 221106 km
                        Time Indication: 0
                        Date: 2019.05.01
                        Time: 18:40:54
                 Freeze Frame:
                        Error Code: 78
    Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 L
       Component: MNS ECE         H48 1060
       Revision: 00000000    Serial number: 399K-067551080
       VCID: 3B75E8A87A82D092C8-806E
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
       Component: TSG FA          H12 0130
       Revision: 00-00000
       Coding: 0002651
    Address 46: Central Conv.        Labels:. 4L0-910-289.lbl
       Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
       Component: Komfortgeraet   H05 0020
       Revision: 0020 ---    Serial number: 01025874170000
       Coding: 7348475
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 4F0 910 177
       Component: Innenraumueberw.H01 0020
    Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
       Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
       Component: DSP-High AU716  H03 0150
       Revision: PROD_01     Serial number: 00000000007131
       Coding: 0000023
    Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
       Part No SW: 4F0 910 280     HW: 4F0 907 280 E
       Component: ILM Beifahrer   H10 0080
       Revision:             Serial number: 00000000010484
       Coding: 0011101
       VCID: 5EB3413C89D0E5BA8F-800A
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
       Component: TSG BF          H12 0130
       Revision: 00-00000
       Coding: 0002651
    Address 56: Radio        Labels: 4E0-910-541.lbl
       Part No SW: 4E0 910 541 T    HW: 4E0 035 541 P
       Component: TUNER EU/US/RDW H42 0630
       Revision: 00000000    Serial number: 388KZ067573203
       Coding: 0000001
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4L0 910 181     HW: 4L0 915 181
       Component: J0644 BEM       H12 0530
       Revision: --------    Serial number: 00000000063708
       VCID: 64C773D4A7BCCF6A59-8030
       Subsystem 1 - Part No: 4F0 915 105 D
       Component: von VA0  2611193015
       Coding: 344630393135313035442056413032363131313933303135
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
       Component: TSG HL          H21 0050
       Coding: 0002058
    Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
       Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
       Component: SDS 3502 UK     H45 0630
       Revision: 00000000    Serial number: 00000611070149
       Shop #: WSC 12336 024 394758
       VCID: 3663F99C41A00DFA37-8062
    Address 6C: Back-up Cam.        Labels: 4L0-910-441.clb
       Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
       Component: J772__Rearview      0050
       Revision: --H12---    Serial number: 525PA8-J6Y40SB
       Coding: 1021001
       VCID: 244733D4E73C8F6A99-8070
    Address 6D: Trunk Elect.        Labels: None
       Part No SW: 4L0 910 945     HW: 4L0 827 851 B
       Component: ValeoHeckdeckel H21 0280
       Revision: --H21001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       Subsystem 1 - Part No: 4L0 910 946
       Subsystem 2 - Serial number: E5030100B
       Subsystem 3 - Serial number: RD22.11.06--H21001000B0070’
       Subsystem 4 - Serial number: 0B0070’
    Address 6F: Centr. Conv. II        Labels:. 4L0-910-290.lbl
       Part No SW: 4L0 910 290     HW: 4L0 907 290
       Component: ILM HINTEN 2    H05 0060
       Revision: AAH05061    Serial number: 002198354-----
       Coding: 0000001
       VCID: 65C16ED0AC86B6624E-8030
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
       Component: TSG HR          H21 0050
       Coding: 0002058
    Address 76: Park Assist        Labels: 4Fx-910-283.lbl
       Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
       Component: Parkhilfe 8-Kan H12 0060
       Revision: 00H12000    Serial number: 06320632104228
       Coding: 0221146
    1 Fault Found:
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                009 - Open or Short to Ground
                 Freeze Frame:
                        Fault Status: 01101001
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 132
                        Mileage: 221098 km
                        Time Indication: 0
                        Date: 2019.05.01
                        Time: 16:17:13
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4E0 910 336 M    HW: 4E0 862 335
       Component: Handyvorb2      H16 1130
       Revision: 00000000    Serial number: 00000007655791
       Coding: 0010900
       Shop #: WSC 17455 000 1048576
    End-------------------------(Elapsed Time: 03:27)--------------------------
    Gateway Installation List:  4L0 910 468
    34-Level Control -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    Wednesday,01,May,2019,19:34:41:59248
    www.Ross-Tech.com
       Coding: 0011775
    1 Fault Found:
    001025 - EGR System
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 2
                        Reset counter: 255
                        Mileage: 221099 km
                        Time Indication: 0
                        Date: 2019.05.01
                        Time: 16:20:03
                 Freeze Frame:
                        RPM: 1428 /min
                        Torque: 144.3 Nm
                        Speed: 68.3 km/h
                        Duty Cycle: 57.8 %
                        Duty Cycle: 20.9 %
                        (no units): 0.0
                        Duty Cycle: 15.4 %
       Coding: 0000504
       Revision: 00H22001
       Coding: 0038033
       Coding: 0000147
       Coding: 0000000
    2 Faults Found:
                014 - Defective
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 133
                        Mileage: 221110 km
                        Time Indication: 0
                        Date: 2019.05.01
                        Time: 19:24:32
                000 -  -
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 255
                        Time Indication: 15
       Coding: 0001046
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 173
                        Mileage: 221110 km
                        Time Indication: 0
                        Date: 2019.05.01
                        Time: 19:27:28
                 Freeze Frame:
                        Temperature: 63.0°C
                        Temperature: 26.0°C
                        Load: 0.0 %
                        Temperature: 37.0°C
                        RPM: 800 /min
                        Current: 0.000 A
                        Temperature: 26.0°C
       Coding: 0011101
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 0
                        Time Indication: 0
                000 -  -
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 133
                        Mileage: 221110 km
                        Time Indication: 0
                        Date: 2019.05.01
                        Time: 19:24:32
       Coding: 0013105
       Coding: 0102142
       Coding: 2593448
       Coding: 0015510
       Revision: 00-00000
       Coding: 0002651
       Coding: 7348475
       Coding: 0000023
       Coding: 0011101
       Revision: 00-00000
       Coding: 0002651
       Coding: 0000001
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 173
                        Mileage: 221110 km
                        Time Indication: 0
                        Date: 2019.05.01
                        Time: 19:24:32
       Coding: 0002058
       Coding: 1021001
       Coding: 0000001
       Coding: 0002058
       Coding: 0221146
       Coding: 0010900
    End-------------------------(Elapsed Time: 03:25)--------------------------
  2. Re: air suspension
    May 2008
    crasher,
    would you know the part number for the rubber mounts that mount the compressor to the car?
  3. Re: air suspension
    May 2008
    thanks for everyone's help!
  4. Re: air suspension
    1837 Post(s)
    Did you get the mount number?
  5. Re: air suspension
    May 2008
    no.
    thanks.
  6. Re: air suspension
    May 2008
    crasher,
    did that scan result show any light on my compressor issue?
  7. Re: air suspension
    #17
    1837 Post(s)
    It suggests an air leak which is usually an air bag.
  1. Please Help Front suspension spring and suspension arms
    By Stavros_Davros in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-06-2018, 02:16 PM
  2. Audi A6 c7 2013 allroad suspension problems (or any c7 with air suspension)
    By Audrius in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-01-2015, 10:53 PM
  3. Self Levelling Suspension Fault - Locked Suspension Yelow Warning on Dash
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2014, 05:01 PM
  4. S Line suspension vs Sports Suspension - Retro fit
    By scoobmw in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-10-2010, 09:23 AM
  5. Mechanical differences between Sport suspension and ordinary suspension
    By Novica in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-06-2010, 05:03 PM
