I am looking to disable High Beam Assist using VCDS coding.
I found three entries where High Beam assist can be enable/disabled.
Address 09 - Central Electric BYTE 5 bit 6
Address 55 - Headlight Range BYTE 5 bit 6
Address 19 - CAN Gateway INSTALLATION LIST entry number 20
Is there any other entry or adaptation that require modification in order to enable/disable HBA?
What I am trying to do is to get rid of 'Main Beam Assist Failure' warning.
