Thread: Starting Golf MK6 2010 1.4tsi dsg
  1. Starting Golf MK6 2010 1.4tsi dsg
    Aug 2018
    Gloucester UK
    7 Post(s)
    A few times I have forgotten to press the brake pedal when the car is Park, turned the key and the engine has started.
    Can someone please advise if this can damage anything and whether there should be something to prevent the engine from starting if the brake pedal isn't applied.
  2. Re: Starting Golf MK6 2010 1.4tsi dsg
    1837 Post(s)
    Personally I don’t understand why an automatic locked in park has to have the brake pedal depressed to start but that aside I would say brake light switch fault.
  3. Re: Starting Golf MK6 2010 1.4tsi dsg
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    That's just VW over safety policy.
    An auto will only start if in park or neutral, I don't know why the brake pedal has to be pressed. As Crasher says the brake light switch could be faulty.
    You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  4. Re: Starting Golf MK6 2010 1.4tsi dsg
    1837 Post(s)
    If you think about it, pressing the brake pedal to start actually compromises safety as in doing so you release the lever lock, the other one which drives me mad is pressing the clutch pedal, start a car in gear with the clutch up and it lurches and you release the key, start a car in gear with the clutch down and then release it, you unleash the torque of an idling engine, not just a cranking starter.
  5. Re: Starting Golf MK6 2010 1.4tsi dsg
    Aug 2018
    Gloucester UK
    7 Post(s)
    I used to have a 2010 diesel Passat and that wouldn't start unless the clutch pedal was depressed. I thought this was to protect the DMF? Another safety feature on the Passat was that the auto handbrake wouldn't release unless your seat belt was worn, which is ok but annoying if you just want to move the car a few metres on your own driveway.
  6. Re: Starting Golf MK6 2010 1.4tsi dsg
    Sep 2009
    12 Post(s)
    That stupid feature annoys me when your working on the engine. It should be in neutral before you try to start the engine. You have to get inside and push the clutch pedal down before you can start the engine.
  7. Re: Starting Golf MK6 2010 1.4tsi dsg
    1837 Post(s)
    Especially irritating on my Tecalamit Mk5 two post lift as you can’t open the door enough to get in, the other three Tecalamits are fine.
  1. Golf 1.4TSi Idle and Noise
    By Golf_TY in forum Golf MK6 - 2009 - 2013
    Last Post: 24-05-2018, 08:25 PM
  2. Question What to go for - Golf Mk6 1.6, 2.0 tdi or 1.4tsi?
    By Benl982 in forum Golf MK6 - 2009 - 2013
    Last Post: 12-02-2017, 04:15 PM
  3. Golf MKV 1.4TSI remap
    By malaroo978 in forum Golf MK5 - 2004 - 2009
    Last Post: 08-07-2009, 10:28 AM
  4. Where is the 1.4Tsi Golf
    By Stardelta in forum New Member Introductions
    Last Post: 11-05-2009, 07:32 PM
  5. Mark 5 Golf 1.4TSI 170BHP
    By 2ndV5Man in forum Golf MK5 - 2004 - 2009
    Last Post: 08-03-2008, 03:37 PM
