Thread: Very strange electrical problem with 04 VRS, help required please.
  1. Very strange electrical problem with 04 VRS, help required please.
    Mar 2009
    OK, I'm in the trade, and reasonably conversant with vehicle electrics.
    We have a 54 plate Fabia VRS here, it's a car I use for commuting, approx 100 miles a day. Up until about 4 weeks ago faultlessly.
    First indication of issues was a sudden refusal to start in the morning, it would crank but not fire. This happened a couple of times, most of the time it would start fine, it would run fine, but sometimes it would just crank. Then a couple of times it died whilst running, once when actually driving.
    A code read pulled up codes relating to the ECU control relay. I can't remember the actual codes offhand.
    We replaced the relay, it was cheap enough from TPS, and a google suggested others had had similar problems. It seemed a good place to start.
    The car was then fine for about three weeks until this week when again it failed to start. A code read wouldn't connect to the ECU, and in just about every other system, there was code for lack of communication with engine ECU. A quick check of the ECU live feed pins, #1 and #2 showed there was no power at the ECU. with the relay out there's power at pin #30 , a temporary jump lead between pins #30 and #87 and the car starts.
    A new relay was ordered and I drove it to work today, some 45 miles with a rigged relay bypass. The new relay has just arrived, been fitted and......Nothing.
    So, the relay in question is #6y0906381 , marked 469. It's in relay position 15. It has 4x pins, #30 , #85 , #86 and #87 . #30 is obviously live feed in, #87 is out I assume directly to the ECU, #86 is unused. #85 is therefore the switch ground. Only it doesn't. I've tested the back of the wire under cranking and it remains live, ground it out whilst cranking and the car starts. So, the big question is, does anyone know where this wire goes, and what grounds it to allow the car to start. The wire in question is blue and yellow. Thanks in advance for any info you can offer.
  2. Re: Very strange electrical problem with 04 VRS, help required please.
    Mar 2009
    Sorted now. For the benefit of anyone who has the same problem and finds this thread by chance, the wire from #85 is pin 18 on the ECU where it is earthed by the ECU. The wire had a break in it, hence no grounding, and no relay switching. Without relay switching the ECU had no live feed. Simple, in a complicated way.
  3. Re: Very strange electrical problem with 04 VRS, help required please.
    Aberdeen
    63 Post(s)
    Good find.
  1. strange electrical issue
    By gdallas in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-03-2018, 09:57 AM
  2. Strange Electrical Problem???
    By paultuk in forum Golf MK5 - 2004 - 2009
    Last Post: 07-11-2009, 12:11 AM
  3. strange electrical faults!
    By hobbit in forum Touran - Sharan - Caravelle
    Last Post: 31-05-2009, 09:00 AM
  4. Strange electrical problem - alarm going off for no reason
    By Disk0 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-11-2008, 10:57 PM
  5. Strange clocks problem! Electrical fault??
    By Kris214 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-07-2008, 02:51 PM
