Thread: 2.5tdi cutting out with fault code
  1. 2.5tdi cutting out with fault code
    Mar 2019
    Ive been out today and the missfire/cut out appears consistantly while accelerating thru 1175 rpm as soon as i hit 1175 it cuts out if i avoid that area by changing gear at strategic times ,it runs perfectly .Any pointers greatly appreciated .
    Heres are latest fault codes after the run out .i cleared them yesterday --
    Address 01: Engine Labels: 059-907-401-AKE.LBL
    Controller: 8E0 907 401 T
    Component: 2.5l V6 TDI 0000SG 0007
    Coding: 07002
    Shop #: WSC 18424
    VCID: 361FA5DB015F
    00008XS4Q9A543EE
    1 Fault Found:
    00550 - Start of Injection Regulation
    08-10 - Control Limit Surpassed - Intermittent
    Readiness: N/A
    Thanks for looking any solutions would be really appreciated
  2. Re: 2.5tdi cutting out with fault code
    1840 Post(s)
    Your pump timing is out, it could be a failed belt as I have seen this before.
  1. Audi A6 2.5TDi Quattro cutting out
    By Davie77 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-02-2016, 05:35 PM
  2. 2.5TDi won't run properly - Fault Code 00550 - Start of Injection Regulation -
    By CliffA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-06-2015, 09:18 PM
  3. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  4. A6 2.5tdi sport fault code pls help
    By thugusher in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 19-11-2009, 06:28 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
