CHASSIS AND BODY |
Frame |
Carbon fiber monocoque with aluminum front and rear frames |
Body |
Removable carbon fiber engine bonnet; fixed side air inlets; fixed rear spoiler with integrated ALA 2.0 System and Aero Vectoring System. Aluminum front bonnet, front fenders and doors; SMC rear fender and rocker covers with increased air inlets. New front and rear lightweight bumpers. New Front diffuser with integrated ALA 2.0 System. High pressure RTM carbon fiber hard top, painted or in visible carbon fiber. |
Suspension type |
Push rod magneto-rheological active front and rear suspension with horizontal dampers and springs. |
Suspension geometry |
Aluminum double wishbone fully independent front and rear suspension. |
ESP |
ESC/ ABS Bosch 8.0 with different ESC characteristics, managed by drive select mode. |
Brakes |
Dual hydraulic circuit brake system with vacuum brake booster. CCB with 6-cylinder brake calipers at the front and 4-cylinder brake calipers at the rear. |
Ventilated discs (front – rear) |
Carbon ceramic brake discs
(Ø 400 x 38 mm – Ø 380 x 38 mm) |
Steering |
Hydraulic assisted power steering with three different servotronic characteristics, coupled with Lamborghini Dynamic Steering (LDS) and Lamborghini Rear-wheel Steering (LRS), managed by drive select mode |
Steering wheel ratio |
10:1 – 18:1 |
Steering wheel turns lock to lock |
2.1 – 2.4 |
Steering wheel diameter |
358 mm |
Tires (front – rear) |
New Pirelli P Zero Corsa 255/30 ZR20 – 355/25 ZR21 |
Wheels (front – rear) |
9''JX20” H2 ET 32.2 – 13” JX21”H2 ET 66.7 |
Kerb-to-kerb turning circle |
11.5 m (37.73 ft.) - average value, variable due to dynamic condition, thanks to LRS |
Mirrors |
External mirrors heated, electrically adjustable and foldable |
Rear spoiler |
Fixed spoiler with integrated ALA 2.0 System and Aero Vectoring System |
Airbags |
Front dual stage driver airbag and front adaptive passenger airbag; seats with side “head-thorax” airbags; passenger and driver knee airbags in selected markets |
ENGINE |
Type |
V12, 60°, MPI |
Displacement |
6,498 cc (396.5 cu. ln) |
Bore and stroke |
Ø 95 mm x 76.4 mm (3.74 in. x 3 in.) |
Valve per cylinder |
4 |
Valve gear |
Variable valve timing electronically controlled |
Compression ratio |
11.8 ± 0.2 |
Maximum power |
770 hp (566 kW) at 8,500 rpm |
Specific Power output |
118.5 hp/l (87.1 kW/l) |
Maximum torque |
720 Nm at 6,750 rpm |
Engine speed, maximum |
8,700 rpm |
Power to weight ratio |
2.05 kg/hp |
Emission class |
EURO 6 - LEV 3 |
Emission control system |
Catalytic converters with lambda sensors |
Cooling system |
Water and oil cross flow cooling system with variable air inlets |
Engine management system |
Lamborghini Iniezione Elettronica (LIE) with Ion current analysis |
Lubrication system |
Dry sump |
DRIVETRAIN |
Type of transmission |
4WD with Haldex generation IV |
Gearbox |
7 speed ISR, shifting characteristic depending on drive select mode |
Standard |
AMT |
1st gear ratio |
3.909 |
2nd gear ratio |
2.438 |
3rd gear ratio |
1.810 |
4th gear ratio |
1.458 |
5th gear ratio |
1.185 |
6th gear ratio |
0.967 |
7th gear ratio |
0.844 |
Reverse ratio |
2.929 |
Final drive ratio (rear – front |
2.867 – 3.273 |
Clutch |
Dry double plate clutch, Ø 235 mm (9.25 in.) |
PERFORMANCE |
Top speed |
> 350 km/h (> 217 mph) |
Acceleration 0-100 km/h
[0-62 mph] |
2.9 sec. |
Acceleration 0-200 km/h
[0-124 mph] |
8.8 sec. |
Braking 100-0 km/h
[62-0 mph] |
31 m |
DIMENSIONS AND WEIGHT |
Wheelbase |
2,700 mm (106.30 in.) |
Overall length |
4,943 mm (194.61 in.) |
Overall width
(excluding/including mirrors) |
2,098 mm (82.60 in.)/
2,273 mm (89.49 in.) |
Overall height |
1,136 mm (44.72 in.) |
Track (front – rear) |
1,720 mm (67.71 in) – 1,680 mm (66.14 in.) |
Ground clearance
(standard – lifting) |
115 ± 2 mm (front with lifting 155 mm) |
Dry weight |
1,575 kg (3,472 lb) |
Total weight permitted |
2,100 kg (4.630 lb) |
Weight distribution
(front – rear) |
43% - 57% |
CAPACITIES |
Fuel tank |
85 liters |
Engine oil |
13 liters |
Engine coolant |
25 liters |
Luggage compartment |
140 liters |
CONSUMPTION |
WLTP cycle |
