Thread: When it rains my indicator messes up
  1. When it rains my indicator messes up
    Jan 2016
    Cornwall
    Hello and good afternoon everyone
    When it rains , I have a problem with my right turn indicator. When I try to flash right instead the left flashes a couple of times and then nothing flashes. Obviously, this is very dangerous as could cause a crash. I have already replaced the hazard warning light as suggested before by others and I've also read about it being a possible broken indicator stalk fault but I'm not sure as it only happens in the rain which to me suggests more of an electrical short somewhere
    does any one know if and where the short would most likely be ?
    where would the circuit be most vulnerable too ?
  2. Re: When it rains my indicator messes up
    Jan 2016
    Cornwall
    Found quite a major leak today so pretty sure i now know whats causing it
    i took away the carpet trim that covers the inner rear light cluster and it was filled up with water so i traced the leak back and its trickling down from top of the boot, so for now i'm keeping that bit of trim off to stop any more water and moisture from getting in and i've placed a cup to collect the water as it's ******* it down at the moment
  3. Re: When it rains my indicator messes up
    Jan 2016
    Cornwall
    yeah looks like theirs a leak from either the rear window seal or the high brake light seal and it's dripping down
  4. Re: When it rains my indicator messes up
    Jan 2016
    Cornwall
    scrap the above as that still wouldn't explain why it's sending a signal to the left to flash , if it was water on the wire it would just flat out short. So i took it to a local audi specialist for them to take a look and they believe the stalk has gone bad and needs replacing which tallies up with what other people have said online whom have had this bizarre issue ... still doesn't exactly explain why it only happens in rain but I suppose it's a matter of elimination
    the leak was coming from the high brake light so that's another job that needs doing and will probably ask the garage as it looks a bit of a pita to access .. lol
  1. Clean up jut before it rains
    By Alex jb in forum Show 'n' Shine - Post your efforts here
    Last Post: 30-05-2017, 10:21 PM
  2. Does it matter if it rains on wax?
    By M1tchy in forum General Detailing/Cleaning Questions
    Last Post: 21-10-2016, 09:53 AM
  3. It never rains...
    By jdp1962 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-05-2012, 05:41 PM
  4. Asda messes up
    By n.w.1 in forum Chat - Anything with wheels
    Last Post: 05-04-2011, 11:00 PM
  5. it never rains but it pours. I need a new clutch.
    By Ben in forum Chat - Anything with wheels
    Last Post: 29-09-2009, 12:45 PM
