Thread: Completely fine, then dies, then all ok again. B6 TDI, CBBB 170PS
  1. Completely fine, then dies, then all ok again. B6 TDI, CBBB 170PS
    Jun 2012
    Peterborough, UK
    The car is performing well, 167k miles though. Drive somewhere, park for 2 hours, drive off later and it stalls after 50 meters or so. Sitting in the middle of the road and it spins over fine but it'll not even splutter.
    Rest it for a minute and try again, after a few seconds it coughs then starts, back to it's old self!
    Feels like fuel starvation so my thoughts turn to the fuel filter, I'll organise a new one, my records show it replaced 40k miles ago so why not.
    Any thoughts?
    Passat 2.0 TDI Sport 5dr Estate (170PS) 3C5 M6F CBBB (Sold 08/04/2019)
    Polo 1.2 TSI 77 kW (105PS) A05 6R1 4F2 (Mk5) M6F CBZB
    If you post for help please close the loop and post how you finally solved the problem.
  2. Re: Completely fine, then dies, then all ok again. B6 TDI, CBBB 170PS
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Getting the fuel filter changed is a no brainer.
    There are two electric fuel pumps on this engine so one could be starting to fail.
    But it's no good & can be expensive trying to second guess these engines.
    So a VCDS scan is the next call after the filter has been changed.
  3. Re: Completely fine, then dies, then all ok again. B6 TDI, CBBB 170PS
    Jun 2012
    Peterborough, UK
    My gut feeling is that some non mechanical component is unwell hence it functions fine after utterly failing, after much digging found a similar tale of woe ending up with this conclusion. Engine code read is the next stop indeed.
    Engine Speed sender cable
    I found a VW technician that was now working for himself. I explained everything that I had gone through and let him free on the car. Within an hour he had found and repaired the broken wire leading from the Engine Speed Sender to the ECU!
  4. Re: Completely fine, then dies, then all ok again. B6 TDI, CBBB 170PS
    Jun 2012
    Peterborough, UK
    Close this thread, did the fuel filter then sold the car a month later. Ah well...
  1. Audi TT 8J TDI CBBB engine noise
    By Rick_C in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 17-06-2016, 12:55 PM
  2. Please Help A6 C7 MMI completely blank
    By Tez0012 in forum In Car Entertainment
    Last Post: 19-04-2016, 09:19 PM
  3. Completely new to the vag scene
    By Chewysouthwest in forum New Member Introductions
    Last Post: 29-03-2016, 09:13 AM
  4. MMI completely broken - what to do?
    By lala in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-12-2015, 07:59 PM
  5. Question 2.0 CR 170bhp CBBB Software Version
    By f33nix in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-03-2011, 06:00 PM
