Thread: dimming mirror repeater causing bulb warning light to come on - voltage or fault?
Results 1 to 10 of 10
  1. dimming mirror repeater causing bulb warning light to come on - voltage or fault?
    May 2009
    Essex
    The repeater in the driver-side wing mirror is notably dimmer than the passenger side and is causing the bulb warning light to display. The bulb is in fact a single LED (I had to replace previously after a knock). Before I go out and buy yet another replacement part. Might it be a case of lower voltage reaching the repeater rather than actually needing replacement? I'm no expert in taking readings but do have a meter to hand to check if instructed how.
  2. Re: dimming mirror repeater causing bulb warning light to come on - voltage or fault?
    Jan 2010
    Yate UK
    11 Post(s)
    I'm a bit hazy on the details as it's a while since I last pulled mine to pieces (after a mirror v lorry argument that I lost) - pretty certain the LED plugs into a connector within the mirror housing, if you put the probes from a multimeter into that connector and see if you get 12v across it, that should tell you which is at fault.
    Now: 2016 C7 2.0TDi BE with Tech Pack, magic parking, ambient lighting
    Previous: 2013 C7 2.0 TDi S Line
    C6 2.0 TDI LE
    A4 2.0 TDI SE
    and an ancient 80 in the olden days...
  3. Re: dimming mirror repeater causing bulb warning light to come on - voltage or fault?
    May 2009
    Essex
    So it was faulty. Water had made its way into the unit. Swapped out for a new one. All good again.
  4. Re: dimming mirror repeater causing bulb warning light to come on - voltage or fault?
    Mar 2019
    West Sussex
    Don't suppose you know which part you bought? I just had the same yet the new unit doesn't work. The old one works but is broken cracked. The new one I got was
    4G5949102B
    Thank you.
  5. Re: dimming mirror repeater causing bulb warning light to come on - voltage or fault?
    May 2009
    Essex
    Quote Originally Posted by FeliceMMorteM View Post
    4G5949102B
    Thank you.
    4g5949102a. Off of eBay. Electronics, Cars, Fashion, Collectibles, Coupons and More | eBay
  6. Re: dimming mirror repeater causing bulb warning light to come on - voltage or fault?
    Mar 2019
    West Sussex
    Blimey. But it says 11-14 :/
    Why @#%$^ lol
    Edit. Clicked the wrong link.
    Bought it. Another anyways. Thank you!
  7. Re: dimming mirror repeater causing bulb warning light to come on - voltage or fault?
    May 2009
    Essex
    Why @#%$^ lol
    Mines MY2012.
  8. Re: dimming mirror repeater causing bulb warning light to come on - voltage or fault?
    Mar 2019
    West Sussex
    Makes it even more confusing.
    So you bought an led strip meant for a later model and it worked?
    Do you still have the eBay item number.
    As have a 67 plate so what I originally got should be fine. But doesn't work. Now got another one on order for my year again 11-18. Am just hoping it's a faulty unit I can return. Far too much money to splash out on just a strip and bit of plastic :/
    Thank you for all your replies though. Will update once sorted in case someone has the same issue.
  9. Re: dimming mirror repeater causing bulb warning light to come on - voltage or fault?
    May 2009
    Essex
    Item number: 143127089965. The title of the ad was: Audi A6 Wing Mirror Indicator 2011-2018 LED Indicator Driver Side which is is range for my model year.
    Best of luck sourcing the correct version.
  10. Re: dimming mirror repeater causing bulb warning light to come on - voltage or fault?
    Mar 2019
    West Sussex
    Quote Originally Posted by krupatel View Post
    Can't make the number work. But it's fine.
    I have now bought an A and B both new and hopefully 1 works. Just want it sorted now. Poor car. Thanks again.
  1. Mk 5 replacement mirror glass and indicator repeater
    By andrewpain in forum Golf MK5 - 2004 - 2009
    Last Post: 20-10-2016, 03:14 PM
  2. Has anyone changed a wing mirror side-repeater bulb?
    By Globalste in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 25-01-2016, 07:22 PM
  3. Wing mirror repeater Broken!
    By Benprice8784 in forum Golf MK5 - 2004 - 2009
    Last Post: 24-11-2014, 04:21 PM
  4. Passat B6 Wing Mirror side repeater removal?
    By Scottiedogg in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-11-2014, 10:11 AM
  5. Mirror housed side repeater
    By cappuccino in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-05-2008, 08:42 PM
