Thread: Mk5 1.6 FSI tappet / hydraulic lifter noise while car warms up
  1. Mk5 1.6 FSI tappet / hydraulic lifter noise while car warms up
    May 2017
    I'm getting a tappet / hydraulic lifter noise on my 2007 mk5 1.6 fsi petrol on cold starts that slowly goes away as the engine warms up over a few minutes. When I take the engine cover off it seems to be coming from the front top of the camshaft housing over cyl 1/2. There's no chain noise from the timing cover that I can hear. It drives really well with good mpg and once warmed up is very quiet.
    I've changed the high pressure fuel pump follower which had a little wear, but still have the tapping. The car has done 65000 miles, previous owner always had oil changed every year by VW, I have also changed the oil using Castrol Edge 5w30 LL.
    I'd be grateful for any ideas or if someone has experienced of this noise too.
    Here's a youtube clip of exactly the same noise, not my car and is no conclusion given in the comments. Many thanks
    2007 Mk5 Golf 1.6 petrol FSI Match - Engine BLF
  2. Re: Mk5 1.6 FSI tappet / hydraulic lifter noise while car warms up
    1840 Post(s)
    Being an FSI there can be a lot of almost diesel like top end noise, without hearing it directly it is difficult to judge. I have had some of these engines need new hydraulic elements and cam fingers, I had one in with very badly worn camshafts which are difficult to change.
  3. Re: Mk5 1.6 FSI tappet / hydraulic lifter noise while car warms up
    May 2017
    Thanks Crasher. Think I'll check the oil pressure to make sure the pumps ok/not blocked next
  4. Re: Mk5 1.6 FSI tappet / hydraulic lifter noise while car warms up
    Jul 2021
    Ireland
    Hi chap, sorry to reply to an old post but my car has exact same noise. 1.4 bud engine. Did you ever get to the bottom of this? Thanks
  5. Re: Mk5 1.6 FSI tappet / hydraulic lifter noise while car warms up
    1840 Post(s)
    The BUD is quite different to the BLF, it is belt drive as opposed to chain and port injection rather the direct FSI. I think you would get better results starting your own thread.
  1. Possible tappet noise
    By headache56 in forum Golf MK7 - 2013 - 2019
    Last Post: 09-03-2017, 10:19 PM
  2. Little help, lifter noise/rebuild head
    By babygirl25stl in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-10-2014, 11:09 PM
  3. Wynns Hydraulic Valve Lifter treatment
    By trueplayz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2010, 09:45 PM
  4. AYM hydraulic lifter installation
    By pappy_77 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-12-2009, 02:48 PM
  5. Please Help 1.6 fsi tappet noise
    By kieraz in forum Golf MK5 - 2004 - 2009
    Last Post: 18-06-2009, 08:12 PM
