Thread: Golf 1.6 TDI start problem
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Golf 1.6 TDI start problem
    1840 Post(s)
    For some reason the diagram I am looking at says the BUS is in the centre consul but on the ones I have done it is up under the dash. Check fuse 2 in the dash side fuse panel and fuse 12 in the engine bay fuse box, check they have power, not just the condition fuse itself.
  2. Re: Golf 1.6 TDI start problem
    Oct 2013
    England
    Thank you Crasher. Massively appreciated. I'm aiming to get back there over the next couple of days with my multimeter. I forgot it last time as we just thought it was going to be a case of plugging VCDS in, reading, wiping and taking it from there.
  3. Re: Golf 1.6 TDI start problem
    Oct 2013
    England
    the outcome of this is as follows:
    we tried starting the car with airbox disconnected - exactly the same symptoms as above - ran for 1 second, but worse than with it connected - so MAF is okay.
    removed and tested all fuses, as well as checking power to all slots on both fuse boards.
    checked for any obvious visual issues - none.
    found canbus module behind steering wheel next to load of relays - all looks dry, secure and undamaged.
    couldn't access EGR valve due to lack of space and tools.
    from what i have found online, the new EGR is likely to be bad as this has the symptoms as a bad immobiliser. starts, runs for 1 second then cuts fuel.
    we could not get my VCDS (genuine) or Autel to communicate with any controller on the car, although there is power going from obdii port to power device.
    friend is going to sell for scrap. if we had been able to communicate with the car, we'd have had a better chance.
    THANK YOU to everyone who contributed on this thread.
  4. Re: Golf 1.6 TDI start problem
    Nov 2020
    Scotland
    Hi did you ever find the fault with the car I have same issue with my mk6 1.6tdi would be great help to know many thanks
  5. Re: Golf 1.6 TDI start problem
    Jun 2019
    Australia
    Unfortunately not. Car wouldn’t communicate with vcds or any other device. Mate sold it as a non runner in the end.
  6. Re: Golf 1.6 TDI start problem
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    If you think the EGR is stuck open preventing the engine from continued running, blank it off.
    If it then starts you will have your answer, although will run in limp mode.
    You can always get one of these to keep it going :-
    https://www.ebay.co.uk/itm/09-EGR-AGR-Valve-Simulator-for-VW-Audi-Skoda-Seat-1-6-TDI-CAYA-CAYB-CAYC-CAYD/181994477873?hash=item2a5fb75931:g:xEUAAOSwhvFZAvH t
  1. Please Help MK5 Golf 1.9 TDI with same old hot start problem!
    By VWVIX in forum New Member Introductions
    Last Post: 06-10-2017, 11:39 PM
  2. Golf 1.6 Hot Start Problem
    By AndyL in forum Golf MK4 - 1999 - 2004
    Last Post: 30-12-2010, 11:46 AM
  3. Please Help Golf MK4 TDI 110 hot start problem
    By j_caie in forum Golf MK4 - 1999 - 2004
    Last Post: 03-02-2010, 09:11 PM
  4. Question Golf no start problem
    By Bald_Rick in forum Golf MK5 - 2004 - 2009
    Last Post: 18-10-2008, 02:39 PM
  5. Cold Start Problem Tdi 110 Golf ???
    By robdcaterham in forum Golf MK4 - 1999 - 2004
    Last Post: 18-12-2007, 01:55 PM
