Thread: VCDS & Oil Level
  1. VCDS & Oil Level
    Port Talbot, South Wales
    44 Post(s)
    I need to reset my service inspection light so was thinking about getting VCDS with a lead as I intend keeping the car long term and think it might be a good investment. What’s the best/cheapest way into checking and resetting fault codes?
    Also, changed the oil yesterday and the digital oil level is showing midway between min and max. Can anyone tell me how much oil is there between the two?
  2. Re: VCDS & Oil Level
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    If you use Android you can get OBDEleven, they haven't developed it for Apple as yet.
    I think there is 1litre between min and max on the V6 engines
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
    1 1 0
  3. Re: VCDS & Oil Level
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    I've got Carista which seems to work well.
  4. Re: VCDS & Oil Level
    44 Post(s)
    Which scanners are you using chaps?
  5. Re: VCDS & Oil Level
    Feb 2016
    53 Post(s)
    Quote Originally Posted by JonathanK View Post
    I use OBD Eleven, compared to other programming and diagnostic software its extremely easy to use.
    I've used VCDS on my Audi's, Peugeot Planet and DiagBox with other cars I've had
  6. Re: VCDS & Oil Level
    Mar 2014
    Edinburgh
    235 Post(s)
    Service light can be reset in the MMI don’t need any other diag software.
    Vcds is expensive but I think it’s worth it as the support is really good. Been using the old hex can cable for like 10 years.
    Obd11 is your cheap and cheerful and can do coding like vcds. I would avoid some of the apps as I’ve seen some cause problems.
  1. advice on buying VCDS/VCDS-lite
    By borakev in forum VCDS - General Questions
    Last Post: 16-04-2019, 05:20 PM
  2. Question Car is not level
    By maccaone in forum Audi
    Last Post: 28-07-2015, 08:57 AM
  3. oil level warning light and VCDS levels
    By svizoman in forum VCDS - General Questions
    Last Post: 11-09-2014, 08:05 PM
  4. Low Oil Level Warning Light on but level OK - Anything else to check
    By new2vwa in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-10-2013, 07:03 PM
  5. Oil level warning light on BUT oil level is correct!
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 02-08-2011, 07:44 PM
