Thread: Emissions Woes (MOT)
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. Re: Emissions Woes (MOT)
    #21
    Feb 2014
    United Kingdom
    Back in, and its gone up LOL!
    1.34 mean average...... a little bit lost now......
    Garage is suggesting their cleaning system, or injectors out and away for testing....... :/
  2. Re: Emissions Woes (MOT)
    #22
    1840 Post(s)
    We could do with establishing your VIN, as I noticed the car is 2004, if it is very early there may be a problem
  3. Re: Emissions Woes (MOT)
    #23
    Feb 2014
    United Kingdom
    Pm'd
  4. Re: Emissions Woes (MOT)
    #24
    Feb 2014
    United Kingdom
    Had a quick look through previous test results, last year 1.98, other years all the way up to 2.60+ and as low as 0.98
  5. Re: Emissions Woes (MOT)
    #25
    1840 Post(s)
    I would not place too much emphasis on that, a few times I have had problems that turned out to be a dirty filter in the test machine.
    Anyway, 01-10-04 build so too late to be the issue I expected.
    It is an almost impossible way ahead and is probably planned by the powers that oversee us but all you can do is change the injectors for perfect and known to be perfect units so genuine VAG at £650.65...... each or maybe a little less from Bosch, without knowing the injectors are perfect you are ******* in the wind. This sort of problem will see all such cars scrapped in the next few years.
  6. Re: Emissions Woes (MOT)
    #26
    May 2012
    Everywhere
    308 Post(s)
    "Had a quick look through previous test results, last year 1.98, other years all the way up to 2.60+ and as low as 0.98."
    Similar to mine , was 2.00 for years , then started using 2 Stroke occasionally , 1.50 , full time use , 1.00 , new thermostat 0.52 and now a 0.34 fast pass
  7. Re: Emissions Woes (MOT)
    #27
    Feb 2014
    United Kingdom
    Quote Originally Posted by Gazwould View Post
    Are you running 2 stroke oil with fuel? what mix? Which oil are you using?
  8. Re: Emissions Woes (MOT)
    #28
    May 2012
    Everywhere
    308 Post(s)
  9. Re: Emissions Woes (MOT)
    #29
    Feb 2014
    United Kingdom
    Would it be okay to do on the BKD?
  10. Re: Emissions Woes (MOT)
    #30
    May 2012
    Everywhere
    308 Post(s)
    Any derv , you notice most in terms of less derv 4 pot high compression vibration with the older cars without balancer shafts .
  1. Air con woes
    By pugville in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-05-2013, 06:23 PM
  2. abs woes
    By Mark Inglis in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-11-2012, 08:12 AM
  3. A4 woes!
    By abimogen in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-02-2011, 07:45 PM
  4. air con woes ?
    By vibroman in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-07-2010, 10:59 AM
  5. abs woes
    By dudimus in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-02-2009, 05:44 PM
