Thread: Rear wiper motor problem.
  1. Rear wiper motor problem.
    Feb 2019
    Bexhill, England
    The rear wiper motor has stopped working.
    To begin with it would start working 10 mins or so after I switched it on.
    I'm sure that sometimes it activated without my touching it.
    It would occasionally stop with the blade in an upright position but this would reset when I next turned the ignitio on.
    My question is, is there a separate controller for the wiper or is it all built into the wiper?
    Is there anything repairable in these things?
  2. Re: Rear wiper motor problem.
    May 2008
    Newbury
    Quote Originally Posted by Finless View Post
    This is a fairly common problem, the controller is built into the motor, the washer pipe leaks and the controller gets wet then you get these sort of problems. ISTR there was a repair kit for the washer pipe, but if the board has got wet and is playing up you may beyond that point (even if the repair kit is still available).
    At the end of the day there is nothing to be lost by removing it and taking a look, but I suspect the only fix is a complete replacement (or just unplug it as I did with mine when it started going off by itself - I drive vans with solid bulkheads so the lack of the rear wiper doesn't bother me in the slightest!)
  3. Re: Rear wiper motor problem.
    1840 Post(s)
    Valeo rear wiper motors are rubbish!
    1 2 0
  4. Re: Rear wiper motor problem.
    May 2012
    Everywhere
    308 Post(s)
    Bish bash Bosch .
  1. Rear wiper motor
    By coup80 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-11-2013, 09:55 PM
  2. Rear wiper motor problem
    By davej311 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-07-2011, 09:15 AM
  3. A3 8P Rear wiper motor.
    By guggy1973 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-02-2011, 10:13 AM
  4. Question A4 rear wiper motor
    By famous geezer in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-02-2011, 06:06 PM
  5. Rear Wiper Motor Problem
    By Ewster in forum Golf MK4 - 1999 - 2004
    Last Post: 08-02-2009, 12:02 PM
