Thread: 08 Golf Grinding Noise
  1. 08 Golf Grinding Noise
    Oct 2017
    London
    12 Post(s)
    Hi would anyone have any idea why I have a little grinding noise when setting off in first and reverse but no other gear
    It only happens on a slight hill start and with a little rev. I can drive off normally without it happening
    I’ve just put in a new dmf and concentric release bearing
    It’s an 08 golf 2.0 Tdi 6 speed
    Going to check engine mounts tomorrow but if anyone has any thoughts please let me know
    Many thanks
  2. Re: 08 Golf Grinding Noise
    Oct 2017
    London
    12 Post(s)
    I should add the noise is very quick approx half a second and is altered by the revs and speed of clutch release
  3. Re: 08 Golf Grinding Noise
    1837 Post(s)
    Did you use all new gearbox mounting bolts?
  4. Re: 08 Golf Grinding Noise
    Oct 2017
    London
    12 Post(s)
    Yes new bolts used, although I should add the noise description of grinding maybe isnt the most accurate. Its more like if you say "errrr" in as high a pitch as you can.
    Although interestingly I just found a similar old thread on here (see link below) where a poster says the dealer thinks its turbo stall when setting off. So I took the car for a drive and went above my normal driving style. Over 3000 rpm in 4th gear going up a hill it went into a no warning light limp mode. Vcds check - overboost. Ive seen this exact fault before and previously had to replace that turbo because of metal fatigue in the turbo blades. Ill take the turbo off this one and have a look but is it really possible this could be responsible for the noise? It doesnt seem like the turbo could make this noise but then a Vw tech would know a lot more than I would. Any thoughts or previous experience appreciated.
    Grinding noise on set off
  5. Re: 08 Golf Grinding Noise
    1837 Post(s)
    Take the turbo off and have it rebuilt locally.
  6. Re: 08 Golf Grinding Noise
    Oct 2017
    London
    12 Post(s)
    Will do crasher cheers, will keep you up to date with what happens, many thanks for all you help in this thread and loads of others I dont post in.
  7. Re: 08 Golf Grinding Noise
    Oct 2017
    London
    12 Post(s)
    This problem was sorted - Im guessing it flywheel noise on a new DMF but if not it was something do to with the clutch kit. Replacement kit fixed it.
  1. Please Help Golf Mk5 2008 1.9 TDi intermittent grinding, rattling noise
    By paulcorrine7 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-03-2016, 08:06 PM
  2. Grinding noise on set off
    By gazwilson in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-01-2014, 05:07 PM
  3. Please Help grinding noise at low rpm.
    By rzlez7 in forum Golf MK3 - 1993 - 1999
    Last Post: 02-07-2010, 01:12 AM
  4. Please Help Grinding noise.... at 2-3k
    By eltoro in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2010, 06:00 PM
  5. Grinding noise????
    By DEL_BOI in forum Golf MK4 - 1999 - 2004
    Last Post: 21-12-2007, 03:32 PM
